Question about Optoma TS400 Multimedia Projector
I want to hang it on the ceiling face down, but the it projects upside down!
Almost all projectors have a menu setting to allow the image to be flipped when ceiling mounted. Be careful not to confuse this with the rear projection setting which it is also likely to have...this makes a mirror image.
Just go in to the menu using the remote or the buttons on the projector and you will find a setting in there
Posted on Apr 05, 2011
Samsung Tv flipped upside down
Most Projector tvs usually have a mode for hanging them from the ceiling, as well as a shelf top.
Go to menu, settings, and then ceiling.
This option will convert the picture to project upside down.
Mar 19, 2014 | Samsung Televison & Video
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
How do i reverse the upside down screen
You turn the unit upside down.
http://support.dell.com/support/edocs/acc/2300MP/en/usage.htm
Go to the menu.
Go to management.
Go to Projection Mode.
Front Projection-Desktop: If you want it to project right side up off a table.
Front Projection-Ceiling Mount: If you're hanging it off a ceiling.
Jun 24, 2011 | Dell 2300MP Multimedia Projector
How can I get the picture from hanging upside down from the ceiling to be the right way?
Go to the menu that alters the orientation of the screen picture for use behind the screen, and or mounted upside down on a ceiling.
Mar 26, 2011 | Office Equipment & Supplies
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
How can i flip the screen up side down on the projecter
Or you can hold down the [A/V Mute] button for about 5 seconds to change the projection setup from Front to Front/ceiling or Rear to Rear/Ceiling.
Mar 31, 2010 | Epson EMP-S4 LCD Projector
CL-610 RUNCO PROJECTION SCREEN IS UPSIDE DOWN. Some one touched the remote control and I am at a loss to fix problem.
turn on your projector as usual, and using the remote, press the 'menu' button.
the menu will appear on the scree (albeit upside-down), and your looking for a setting like 'setup' or 'orientation'.
some runco's need a special code to get into some menus, but the orientation selection should be easy.
once you find the menu, there are usually 4 choices; front projection/floor mount, front projection/ceiling mount, rear projection/floor mount, and rear projection/ceiling mount.
the most common is 'front projection/ceiling mount'
Dec 08, 2008 | Televison & Video
Picture is upside down on screen
go into the menu using either your remote or the button on the projector itself. At the top are several options i.e. "picture" scr-adj. Click over to the right ONCE to "SCR-ADJ" this stands for source adjust. Then look for something called like PRJ mode (projection mode) This tells the projector which direction to display the image so that incase you want to hang it from the ceiling upside down you can. Click down to that menu option. You will then have to click over to the right in order to see your options. If you are using it hanging on a ceiling you want it to say "ceiling front" if it is merely sitting on a cart or a shelf just put it on "front".
Good luck.
Aug 12, 2008 | Sharp XR-10X Multimedia Projector
180 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
