Question about Bosch 9.1 cu. ft. / 258 liter Upright Freezer GSU29424GB
Hi - I have a Bosch GSU29424GB/02 upright freezer. Recently it has started to look like it is not keeping cold enough as the relevant temperature light will flash (for hours). There is little evidence of food thawing...perhaps the bread at the very top is slightly soft when it does this. My thoughts are that it is either the thermostate or perhaps something is triggering to go in to frost free defrost mode for frequent and extended periods. Anyone got any advice...and/or can I repair this myself if I can get parts Thanks Jonathan
frcs68
  • 1605 Answers
SOURCE: the alarm button is flashing
-18c is about 0 F. it shold be cold enough to freeze you know what.
you might want to turn the tempture up a little.
Posted on Apr 01, 2009
bobicehouse
  • 1524 Answers
SOURCE: problems with the temperature dropping quickly
Sounds like a refrigerant charge problem.
Posted on Jul 19, 2010
domotek
  • 591 Answers
SOURCE: I have a Bosch Exxcel
I would first try a complete defrost, by removing all food, unplug the freezer and let the door open for two days, (you can take the opportunity to clean the inside ha ha!) this is to make sure there are no ice build up around the sensors, than re connect the power and let it freeze up again, (on hot humid days the automatic defrosting cycle has difficulties to perform), don't forget to empty the water pan under the freezer (if equipped) and to put many towels around the bottom as well, it could leak some water on the floor... if the problem persists, than have it checked by a professional technician...
Cheers!
Posted on Jul 07, 2011
heatman101
  • 43501 Answers
SOURCE: Bosch FD8709 Fridge Freezer (American Style)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 05, 2011
Testimonial: "Thank you for your generous support. I found a lot of dust under the unit, turned it off, cleaned-up, and it appears to be working at the moment."
  • 500 Answers
SOURCE: We have a Bosch upright freezer GSN32A20GB.
I mikeg386,
The Freezer is getting to warm, and not able to reach the desired temperature of -22 degrees.
First off, I'd change the setting to between -16 to -18 (You do not need more cooling, anything above that is going to consume too much power to reach, and too much wear & tear from the compressor - that is why it is hot)
Then I'd check the condenser piping at the back of the fridge for any fluff or dust buildup. Remove these with a vacuum cleaner. Alos check the seals on the door for any signs of perishing, if cold air escapes from the door, it will struggle as well. A nice tip is to poor boiling water over the seals to allow them to expand.
Leave your fridge for 8 hours and check it again, should be OK then.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Posted on Sep 12, 2011
My freezer is blowing but not cold enough to keep it frozen
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor.
Hope this help in solving the problem. take care....
Sep 15, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Freezer not cold enough
the dryer is already sock ,, you need to change it and refill the gas
Jan 24, 2010 | Freezers
Freezer is not cold enough . I cannot seem to find the mechanism that controls the temperature.
You need to check first that there is no leakage of your gas in your compressor system thats responsible for cooling the refrigerator. If you have the manual you an read it to locate the regulator
Oct 14, 2009 | True 31 cu. ft. / 878 liter Upright...
I have a 4yr old 13.7 cubic upright frigidare freezer. Running all the time, I defrosted it recently (only minimal frost/ice on base behind basket) after noting top shelf warmer than others and food...
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
Jun 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
The alarm button is flashing
Apr 01, 2009 | Bosch 9.1 cu. ft. / 258 liter Upright...
Need a freezer for garage in the Dakotas
Refrigeration units don't care for the most part how cold it gets with exceptions. The oil is not a concern, neither is manual or auto defrost. Refrigeration units that are required to operate in cold temperatures, say below 30 degrees F. have crankcase heaters on them to heat the oil which keeps freon moving out of the oil and the bottom of the compressor. Otherwise when the compressor starts the cold freon will we sucked out of the bottom of the compress with a large quantity of oil which can destroy the compressor. Another item used for cold weather application is a fan control sensor which keeps the condensing temperature up or the unit will again remove the oil from the crankcase. It may work fine for a quite a while, but it will fail in continuously cold temperatures.
Nov 22, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Upright freezer problems
Hi Robert,
Happy to help.
Sounds like it is low on freon
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 24, 2008 | Frigidaire Freezers
Hotpoint FZA50 Freezer not cold enough
try it on max setting. lint clogging up stuff in the back? needs defrosting? low on refrigerant (freon)? call repairman for that last one
Jul 10, 2007 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Bosch 9.1 cu. ft. / 258 liter Upright Freezer GSU29424GB Logo
75 people viewed this question
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
