Question about Samsung Washing Machines
I have purchased a samsung WF7602NAW and will not start and shows code (de) and starts to beep.
    Brigadier General:
  • 6,277 Answers
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Posted on Apr 05, 2011
  • 3 more comments
  • markvdb100 May 07, 2011
    Hello John, if the Solenoid is new, just replaced, and DE remains... where is the sensor that causes that?
  • john_cross May 07, 2011
    Hi Mark,
    Have you just replaced the solenoid or a service engineer, please? I would expect the sensor to be behind the actual door catch and 'testable' by operation by a small screwdriver poked through the catch aperture.
    Sorry if you are struggling- I should put 'the sensor' before 'the solenoid' in my notes but that is why I say either/or ;-0) I hope this helps.
    Cheers, John C
    I had to replace this relais because the metal contacts got overheated/plastic melted due to oxidation that caused a bad connection which eventually overheated. A common problem whith these locks as far as I know....
    Is there someway I can 'reset' the machine or force a 'door locked' sensor position?
    Sorry Mark, I do not know. Samsungs are not my best ;-0(
    Post you situation as a new thread stating that you had to change the relay/solenoid 'cos it was 'cooked' and that you still have the 'de' and someone should be able to help. Sorry again!
    John C
    Hi John, thx for your efforts! I've temporarily fixed it now. Just shorted the wires that form the sensor part of the doorlock. We don't have any kids around that'll open the door whilst it's running ;-)... Obviously somthing is wrong with the electronics that tell the doorlock to go into lockposition...
Code dE
As Far As I Am Aware That Is A Washing Machine Door Error Code
Apr 21, 2014 | Samsung SW62ASP Top Load Washer
Code dE showing
Does your washer have a lid lock mech. If so and the lid is not locking or is staying locked you may want to check the locking adjustments
No osd menu on samsung sde-4001n dvr
yea no osd menu, it was the same for me, but after a couple test, i found thats because it does not detect de vga cord correctly, duno why only with this model, if you use kvm or a dvi to vga cord, happens , i connected a old vga lcd screen and wala! , maybe after a firmaware update may fix the problem :)
Apr 22, 2012 | Samsung Sde4002 8 Channel Dvr Security...
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
Try to start machine code de showing and beeping
DE = Door Error.
Latch, sensor or similar has failed.
See this link:
LG -
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 13, 2011 | Washing Machines
I just purchased a slightly used HP m9340f Pavilion Media Center PC. It won't boot up... it just beeps. Nothing shows on the monitor.
The beeps normally are a code which tells you what problem has been detected and is keeping the computer from starting. You can find information about interpreting the beep codes and what to at HP's site here. The most common causes of beeps and no start is bad memory or video. I'd suggest making sure the memory modules are firmly seated in their sockets. It's possible that poor connections are keeping the memory from being properly detected.
Jul 29, 2009 | HP Pavilion Media Center m9340f Desktop PC
Error code de
hi, i've got the same problem. But when i leave it for a minute or two with the beeping, it will automaticaly start its washing program. Without opening and closing the door. We probelbley need a new door sensor. I've seen them on the internet for $100. But as long it's washing like it does now. I'am leaving it like it is.
Aug 21, 2008 | Washing Machines
Washing Machines Logo
330 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
