Question about John Deere Garden
I replaced cam, water pump and fuel pump on my jd 345. after running the mower a couple of hours, white smoke (steam) started coming out of the exhaust. i took heads off and replaced head gaskets but that did not fix it. the radiator/motor will not hold water and the water will run out of exhaust without motor running. what is the problem?
  • 6982 Answers
SOURCE: white smoke or steam coming out of exhaust pipe,
Its funny that everyone has solved the problem without any answers to critical questions. In this case, everyone is right and everyone is wrong. ONLY careful testing and observation will determine if there is an actual problem. I do not solve problems just to be first. Even in a hands-on situation I refuse to jump to conclusions before testing, otherwise you run the risk of at best, "chasing your tail" or at worst, tearing into a perfectly good engine to prove nothing!!!
Happy New Year!!!!
Posted on Jan 01, 2009
  • 23 Answers
SOURCE: water and white smoke comming out exhaust
your cooling system is preasureising due to a leaking cylinder head gasket the white smoke you see is coolant passing through the exhaust valve on the offending cylinder have the cooling system tested for CO content hope this advice helps
Posted on Feb 24, 2009
SOURCE: Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Posted on Mar 19, 2009
  • 4 Answers
SOURCE: JD LX188 rider mower engine runs rough
black exhaust would usually indicate that the engine mixture is too rich. This can be caused by a dirty air filter which may need replaced if it is the paper element type, or may need washed out if the foam type. It may also be that the carb' needs the mixture adjusted and this is done by turning the adjusting screw clockwise a very little at a time until the engine runs smoothly without black smoking. Beware of over tightening the adjustment screw as the end may be damaged or worse, nip off. hope this solves your problem
Posted on Mar 30, 2009
yotaguy
  • 232 Answers
SOURCE: water in oil
I have yet to see a cracked head on a 22R,so more than likely a blown head gasket,unless you overheated and warped the head and worst case a hole between the cylinder wall and water jacket(this is pretty rare).The only way to tell short of using some expensive tools or taking to your local shop is to pull the head and inspect the gasket for leakage wich is generally fairly obvious(separation of the gasket layers,oil and water between water and oil passages)and checking the head deck for warpage.If there is obvious leakage in the gasket you're looking at a top end gasket set if the head is slightly warped you can get away with a thick graphite head gasket,I personally use these as they are very forgiving on slightly warped and scratched head decks and inepensive also,but a severly warped head will require milling at a machine shop or replacement.
Posted on Apr 09, 2009
What does the white smoke coming out of the top of the flu on my oil boiler mean
White smoke means steam and that would be caused by a leak in the heat exchanger coil of water in the fuel.
May 02, 2015 | Biasi B-6 Oil Boiler w/ Riello Burner -...
I have a J.D. 345 and i think the cam gear may be broken but not sure. I have compression coming from both spark plugs when cranking but the push rod that allows the fuel pump to function isn't moving .
Not sure about the JD 345 but in general if the fuel pump pushrod isn't moving, there's only one solution, I'm afraid, you'll have to partially strip the engine. Removing the rocker covers will enable you to see if the valve gear is operational. If it is it' s possibly the fuel pump cam or follower, if the valve gear isn't working then it's the cam drive, could be a broken belt or chain or a sprocket key has sheared. Good luck.
Oct 29, 2013 | John Deere Garden
I am trying to get a JD riding mower with a 17 HP Briggs to run that has been parked for a couple of years. Ive replaced gas & filter, cleaned carb and verified fuel pump is working. It will only run if...
You need to soak the carb in a good carb cleaner for a couple of hours then blow all passages out with compressed air, this should dislodge any junk.
Aug 20, 2013 | John Deere Garden
I have a F725 mower. Runs fine when 1st started, after approx an hour it stalls and stops running. Acts as if out of gas. Sometimes you can choke it and it will run a while longer. Changed fuel filter...
Could be ignition module overheating, but then the coke influence doesn't make sense. Once it quits try either a shot of starting fluid in the carb, or tiny bit of gas. If it runs then you know you have a fuel problem. Check to be sure the gas cap is venting and check to be sure you're not getting vapor lock after the motor gets so hot. You could also disconnect fuel line to be fuel pump is pumping. Does it have a kawasaki engine? Beware of some plastic cam gears.
Aug 11, 2010 | John Deere Seat For F710 F725 F735 Riding...
Hello my name is John. I have a 345 John Deere lawn tractor. The problem is that it starts idles rough won't idle up and does not run strong enough to move the mower. It just chugs and puffs white smoke...
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
Jun 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have lots of white smoke coming from tail pipe when starting
White smoke is either steam or coolant. Oil smoke is blue, fuel is black. The smoke is water or coolant boiling and then coming out the exhaust as vapor.
If the weather is cold, water will condense in the exhaust system after shutdown, then come out as steam on startup. This is OK. If you see the smoke after driving on the highway for an hour or it is an all-the-time event, you have a problem.
If you have a problem, most likely, at this age, it is a leaking head gasket. Possibly the cylinder head is cracked. Valve problems are possible but less likely. Keep track of how much coolant you add to keep it at the full mark. Obviously, this is expensive to fix.
The problem was bad/worn valve stem seals which allowed oil to seep into the cylinder heads when the engine wasn't running and burn off when the engine was started creating the white smoke. If it is valve stem seals, they are not too expensive to replace however I would suspect your mechanic will want to do a complete valve job which is a little more costly.
Hope thos help (remember comment and rated this).
May 10, 2010 | 1990 Lexus LS 400
White heavy smoke coming out when engine running whith a slight noise from the engine can you help.
head gasket has gone white smoke is water vapout (steam) best advice here is to trade it in on plan renewel
Mar 07, 2010 | 1987 Peugeot Liberte
Garden Logo
218 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
