Question about JVC AV-48WP30 48" Rear Projection Television
The color is kinda faded an blurry (sorta) its a 50 inch JVC projection TV..... i have tried to go into the menu screen an change the color the brightness an all that but when i do it doesnt change it very much. Is this an expensive thing to fix?
  • 4 Answers
Well, the bulbs can be up to 260 dollars per lamp, depending on the TV and if the bulbs are separate.It's not very hard to change them out if you have a little experience in taking those types of items apart, but I would definitely look into it.
Posted on Apr 05, 2011
My Samsung's picture is starting to fade and all the colors are turning a reddish color. Does this mean I need to change the lamp? I just did that about 6mos ago. What now?
with TV on bring up the menu. If the menu screen is NOT affected, the DMD board should be fine. It menu is affected, DMD board is likely the reason.
Also check the color wheel, sometimes when they are going bad they will translate the wrong colors or even make a loud pop and shut TV down. If the bearing is going bad on color wheel, it can make a grinding/squealing kind of noises and sometimes even make the TV vibrate.
Im not a TV specialist. Just trying to help with what I have experienced with this set.
Feb 27, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
The picture is a little blurry and the words a fuzzy
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Hitachi 50DX01B 50" Rear Projection...
Lines, a little blurry, a little movement
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Jun 10, 2010 | Hitachi 51F59 51" HDTV Projection...
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
  • Screen looks 3D
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
My tv the color is fading and now in one corner it is blurry and kinda red. Not sure how to describe this.
Ur convergence is dead.Have coner blurry red colors?U must know how to solders to solved this.Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 17, 2010 | Toshiba 46H84 46" Rear Projection...
Blurry vision on picture
This is a very common failure on Projection TV sets.
Screen looks 3D
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | JVC AV-48WP30 48" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
IS THIS TV PLAYING OUT
Color separation is called convergence mis-alignment......that
problem can be repaired...............Blurry,darker when cold may
be a bit of difficulty..............Have a skilled tech give it a look.....T.
Nov 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
98 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
