I JUST REFILL MY COPIER AR5320E WITH A TONNER WHILE PRINTING IT STARTED SHOWING F2 WHEN PRESS PRINT IT SHOWS 04 WHAT CODE DO I USE TO CORRECT THIS PLS
  • 1,326 Answers
It means that the toner was possible installed wrong. I would remove the toner you just installed and let the copier come to Ready, then reinstall the toner bottle. You may also, have a defective toner bottle???? Good Luck......
Posted on Apr 06, 2011
What is the reason for blank copy in ir3300 copier
Check the fixin unit,lamps,thermistor,thermal fuse
Aug 02, 2014 | Canon IR 3300 Digital Copier
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
WHEN PRINTING HP LaserJet P3005n Printer A MESSAGE TONNER REFILS, BUT TONNER FULL
Toner cartridge memory counts how many print outs passing through it, once memory sensed yield count crossed, printer will say that "low toner" , after couple of prints it will says to "replace the cartridge". If you refilled this cartridge with out replacing the memory printer will treats its old cartridge only.. Replacing the memory will solves your problem.
Ideal memory chip...
Sep 05, 2012 | HP LaserJet P3005n Printer
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
After refilling the tonner printer showing tonner
after refilling the tonner of xerox workcentre 3119 printer showing tonner empty message
Feb 20, 2010 | Xerox WorkCentre 3119 Laser Printer
TUNER ERROR SHOWS
REFILL THE TONNER OR TRY CLEARING IT BY PRINTING SELF TEST
OR REPLACE IT IF IT IS IN WARRANTY.
Nov 05, 2009 | Samsung ML 1610 Laser Printer
What does the error code F2-40 mean on a Sharp MX-M4501N?
according the manual F2-04 means drum data read problem,may be it can be reset why don't give a try;
1, power on,
2, press "clear","interupt", "0", "interupt"
3, press 14 prss start
4, press clear
Dec 16, 2008 | Sharp AR-207 Copier
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Black Lines and Very Harsh noise on a new Tonner. No printing with New tonner
Those printer tonners are very tricky to refill and a bad refill induse on bad printing so you can clean the drum (the round green thing) with isopropilic alchool. If it continues it indicates that the blade ( inside tonner plastic blade that cleans the excess tonner powder) is durty and you can clean it too with the same alchool. If it continues replace the tonner cartridge.
Feb 12, 2008 | Samsung ML 1710 Laser Printer
37 people viewed this question
k24674
jasbo
jasbo
