Question about IBM X236 Server
I have 2 IBM x3690 Servers with 5 SAS 300 GB hard drives connected to Server RAID M 5015 controller. 4 HDD are connected with one backplane and the last one connected with 2nd backplane. While i configure through Server Guide it only detects 4 HDD. But at webBIOS it shows all hard disks and two of them are with same port number. Please hep me resolve this issue. Thanks in advance Shafeeque.
  • 12 Answers
SOURCE: While installing debian on IBM Xseries 306m it can't detect HDD
Have you initialized the disk from within the BIOS ? if not when you boot the server it says there are no hard disks.
Posted on May 07, 2008
  • 93 Answers
SOURCE: SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Posted on May 19, 2009
  • 105 Answers
SOURCE: new install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
Posted on May 26, 2009
paand
  • 147 Answers
SOURCE: raid 1
there must be some key on the startup to enter into the raid menu. And in that raid menu you can create raid .
Posted on Jun 23, 2009
nicarta
  • 506 Answers
SOURCE: raid 10
The porn site have installed it add-on your browser. Check and see if you can see any strange program on add and remove software program window. If you can remove it but you must be sure before doing that. Alternatively, download a malware removaMicrosoft
Posted on May 29, 2010
Raid 7k controller not responding properlly error 2807
This could be an issue with the Raid backplane. If under warranty I would replace the backplane.
Even if no warranty you might be able to find one cheaply used.
regards,
Mike
Oct 10, 2012 | IBM X236 Server
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
Raid Driver
send me you querry clearly to my email id:- venkatesh.k@cacheperipherals.com
Mar 15, 2012 | IBM System x3200 M3 7328 Server tower ...
Can not setup RAID 1 on an IBM X3200 M3 Server
you can access the raid controller using the BIOS and system devices>>> refresh>>> then select the controller then create your raid...
don't know why they move out from the POST the controller its really stupid''' Sorry..
Feb 04, 2012 | IBM System x3200 M3 7328 Server tower ...
In my IBM X226 server 2 HDD became unavailable in RAID 5 configuration. now I have replaced the hard disks and rebuild process is continuing. 1962 operating system not found error message is being shown...
Raid level 5 gives you some redundancy in your raid however it only allows you to lose one hard drive, two hdd lost would not permit to recover from. the parity bit can rebuild one hard drive but not two, sorry your raid might be lost
Aug 15, 2010 | IBM xSeries 226 Server
Performed a clean installation of windows xp sp2 which I purchased and the installation won't complete it says error 1 cannot boot from drive how to fix this ?
you need a raid controler then use a raid driver disk before install windows, because you use sas as primary disk. these disk is for unix and server blade server, using sometimes windows server as Op System.
is a tradicional steps when using special hard disk
Aug 08, 2010 | IBM (40K1042) 36 GB SAS Hard Drive
Confuguring raid5
Hi
You would need 4 Hard disk drives in total. you would need to create 2 RAID 0 (striping) and then Mirror them (RAID 1). to elaborate, HDD A&B will be at RAID 0 as well as HDD C&D. after, you would have to Mirror your two RAID 0. (raid 0+1 is also known as raid 5)
Hope this helps.
Jul 09, 2010 | IBM x3400 Server
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
Raid 1
Jun 23, 2009 | IBM x3400 Server
IBM X236 Server Logo
82 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
