Question about HP LaserJet 2820 Printer
The bulb in my hp 2820 printer does not move even when am scaning
  • 4 Answers
If the scanner head does not move, you need to check two things:
1) If you look into the flatbed while it IS NOT ON (important there), if the bar is off track, it needs to be placed back onto the track.
2) The motor for the scanner apparatus is dead. Buy a new AIO Printer.
Posted on Apr 05, 2011
Scanner error 5 in hp m1522nf
its a very common error in this printer. The error its usually in the step motor that moves the escaner. Its the same motor used in other printers such as 3052, 3055, 2820, 2840. Or you can buy it in any electronic house just looking at the code
Feb 05, 2011 | HP Office Equipment & Supplies
HP 2820 scanning steps
http://www.google.com.ph/search?q=how+to+use+scanner+in+HP+LaserJet+2820+Printer&ie=utf-8&oe=utf-8&aq=t&rls=com.yahoo:en-US:official&client=firefox
go to this link above, on the bottom you can see HP Color laserJet2820/2830/2840 userguide HP color Laser Jet, left click on this file and you can download the user manual of this printer.
Nov 27, 2010 | HP LaserJet 2820 Printer
Scanner error 6 how i can give it a solution?
disconnect the printer cable (USB Cable / Data Cable) and swich off and on the printer...... it will solve the problem
OR
clean scanner glass if not work cleane scane bulb.
Please post you feedback and Vote if the problem resolved as per your satisfaction.
Aug 17, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Very light print out of hp p1505 laser printer is cery light even after changing tonner and cleaning scaning unit.
This could be color miss registry, even though your printer is a monochrome printer there is a sensor which determines the color density, Black being a color, and if the sensor is damaged will cause issues like fading. Make sure you are using hp original cartridges, and if the problem is still there, contact hp for warranty options, hp's tech support line is 1800-334-51440.
Al
Eliteprintersolutions@gmail.com
Jul 11, 2010 | HP LaserJet P1505n Printer
Hp 2820 prints only on right side of page
Yes, you will need to replace the drum unit as well. be sure to shop around so you can get the best price because some people mark up the price for that part. You can check the status of your supplies from the printer itself by pushing the "menu" button the printer and scrolling through until you see something about supplies status then press the check mark button.
Jun 02, 2009 | HP LaserJet 2820 Printer
Hp 2820 scanner error 5
I'm not sure if this will help or if this is the same as i had but I had been given A laserjet 2820 which keep't coing up scanner error 5 the chap that had it before me contacted hp service & was told to replace scanner unit which he did & it was ok for a while like 6 months & started then started again.
The problem he had was powered up ok till it came to scanner bulb warming up the scanner unit moves back & forth then try's to escape through the right hand side of case.
This is because it cant see the home position white strip under the scanner glass all you have to do is remove top section of the scanner unit complete with scanner glass & clean the under part of the scanner glass the white strip is located under the wide gray panel as you look down on the scanner glass with the lid up. hope this is of some use. my unit has been working for some time now
Dec 29, 2008 | HP LaserJet 2820 Printer
HP Color Laserjet 2840
Need to order a replacement FUSER it's located in the rear of the printer. If you live in the USA you need 110V if you're in Euro 220V see below for the part number you need to order.
RG5-7602-000
RG5-7603-000
Fuser ***'y, 110V, CLJ 2820/2840
Fuser ***'y, 220V, CLJ 2820/2840
CLJ 2820/2840
Aug 06, 2008 | HP LaserJet 2820 Printer
HP Laserjet 2820 getting error 10.1004 supply error when installing a new imaging drum. Anyone ever got this error msg? Thanks
Does it work with this error....if so you wanna
make sure that you have a HP cartridge, sometime the chipset is not recongnize....and you have some function that doesn't work. If you try all this, call HP.
Mar 26, 2008 | HP LaserJet 2820 Printer
Scanner error 6
in my network i have hp M1005 printer always i'm getting this msg "scanner error 6 turn off
then turn on"
when i make turn off and turn on again same msg comming
how can i solve this problem...
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
HP Color LaserJet 2820
The flat bed scanner assy is bad and needs to be replaced. The part number is Q3948-60191. Hp recomends taking it to a repair center for replacement
Jan 13, 2008 | Office Equipment & Supplies
HP LaserJet 2820 Printer Logo
44 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
