Question about HP Office Equipment & Supplies
My printer will not load and the window says the carriage is jammed. It is an HP Officejet 7410 All-in- one. It first had the message Paper jam and after I opened it and there was no paper jam I got the message the carriage is jammed. The Ink cartridges are jammed in the left side. When I try to clear it there is a noise as if it is trying to pull paper thru but nothing happens. The error message comes back on the screen.
    Novelist:
  • 180 Answers
1. Check if there are broken parts inside the printer-carriage area
2. Turn the printer on and off
3. Clear any paper jam by opening the rear access door at the back of the printer. If there are no paper jams. Clean the rubber rollers with a lint free cloth that is moist with water
4. Make sure that the carriage can move freely
5. Remove then reinstall the ink cartridges
6. Make sure that the control-panel faceplate is correctly installed
7. Plug the printer directly to the wall outlet
8. Perform a partial reset on the printer.
a. Unplug the power cord from the All in One
b. Press and hold # and 3 while plugging the power cord
c. Do not release the two buttons unless the printer would say reset
9. Try to print
10. If this would not resolve your issue then the printer sensor is already defective.
Posted on Aug 06, 2008
How to clear carriage jam?
Hi there! in order for you to clear the carriage jammed of your 7410.. kindly check this link below..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&key=null&product=391194
if the steps didn't help you on how to fix the carriage jammed then there's something wrong with the printer itself.
May 17, 2011 | HP OfficeJet 7410 All-In-One InkJet...
It say carriage jam
Hi friend,
What probably happened is that paper jam caused the carraige alignment sensor to get out of place or to get covered, moved, etc and the printer doesn't know what to do...
What I would suggest trying is, unplug the printer, try pulling the carraige out to the center and then close it and plug it back in, see if this kicks it enough to reset itself.
Thanks,
Mar 20, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Carriage return error does not stop.
there is a piece of paper jammed.Follow clearing paper procedure.If there is no paper jam push the reset button
Sep 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
C6180 clear carriage jam
Change ur categer and clean ur inside the printer,and delete old documents.
Jul 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 Poor printing, carriage jam message(fake), loud noise
Check the plastic strip that you'll see along the carriage track. Make sure it's clean. Take a soft cloth and dampen it. Run it up and down the strip and make sure it's clean. If there's any ink on it, it could cause carriage jams. The strip has tiny lines on it which tell the electronics where the carriage is. If the strip is dirty, you'll get jam messages and sometimes the carriage will slam against one end or the other.
Apr 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Error message
hi,
below is the document that i want you to follow to somehow resolve your issue.
CLICK HERE TO VIEW DOCUMENT ==>> CARRIAGE JAM
Please let me know the outcome after you perform the steps.
thank you so much.
adonscott
Jul 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One paper jam error
well...let's just say your printer is speaking to you clearly...and too bad about warranty...you may want to consider a replacement printer, and recycle that one responsibly.
you may find a solution through this link(look for the google search, and select the fixyourownprinter.com option button).
Mar 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
287 people viewed this question
Seeker5211
Seeker5211
