Question about Garden
Broken latch spring part #10191 001 - Garden
4 Suggested Answers
SOURCE: spring for the door latch is broken
As a follow up to MicrowaveSvc: first thanks for the insight. Second I found the spring mount entirely broken off from the door. I did find an anchor point molded in the door near the bottom. I tied a length of waxed whipping twine between the anchor point and the spring and adjusted the length to make the spring firm. I have a picture if you can tell me where to send it. David Smith
Posted on Sep 08, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: microve latch/spring assembly ... have a broken
Unfortunately, the exploded views do not show the innards of the door.
So as new latch head is not available separately, so if you cannot fix yours, a whole new door will be needed.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
There's probably a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
You can use use epoxy and some kind of hardware to fashion a new spring mount.
If you have to do any gluing, make sure the parts are squeaky clean and dry before you glue them, or it will not hold up.
Posted on Oct 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: my detergent door will not latch, took it apart
The timer must be in the OFF position for the cup to latch.
Posted on Feb 21, 2011
Testimonial: "something so simple that i overlooked thank you so much for the quick and effective remedy to this not so hard of a problem. "
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door doesn't latch
Can you move the latch in the door? This is spring loaded, maybe the spring is broken
Mar 09, 2013 | Maytag MMV1153A Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Microwave door will not latch closed
I just had this problem with a Samsung microwave/hood combo. I pried/popped the inside molding out with a screwdriver. The little lip that the spring attached to had broken. I drilled a hole in the center of the door latch, reattached the spring, replaced in door, replaced inside decorative molding, and fixed in 5 minutes. Thank goodness because it's such a pain to replace these units.
Jun 30, 2010 | Neff B4540 Stainless Steel Electric Single...
I have a frigidaire model fmv156dbf and the door latch will no longer operate. when i opened up the door i saw that the spring that is supposed to operate the latch was no longer attached. where the spring...
We have the service manual and have uploaded it to our site here to help you.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order parts here if needed.
May 26, 2010 | Frigidaire Microwave Microwave Oven
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
The back seat latch on my 2005 Honda CRV not not
check to see if parts are jammed in the path of movement
Sep 12, 2009 | 2005 Honda CR-V
1998 subaru legacy hood latch is broken :(
tre spring is on the latch itself,my guess is that the latch needs a little lube,work the area of the latch that the cable slides into with a screwdriver,it should spring back after you lube it
Sep 11, 2009 | Subaru Loyale Cars & Trucks
Spring for the door latch is broken
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | Sharp R-1480 Microwave Oven
Door Doesn't latch shut
Usually it's not thespring but instead the "latch head", which has a little loop on the backside to hold the spring. The loop breaks off.
The latch head is the long plastic piece with two protruding hooks which activate the hidden door switches.
The door will need to be taken apart (but not removed from the oven!) to get to the latch head. See the attached example photo.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Sharp R-1480 Microwave Oven
Garden Logo
278 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
