Question about Philips (DBMMS460) Computer Speakers
I am having problem with my woofer . It is huming and booming all the time. What is causing this annoying problem ?
    Novelist:
  • 151 Answers
Best guess, you should check that..
A, your speakers are connected correctly (a subwoofer connected to the center output will give you that problem.
B, The input is correct - just like the speakers, if the amplifier input is wrong the wrong noises will come out of the wrong speakers.
C, check the settings in your audio control panel on your PC - make sure you are using the settings for 5.1 surround not 2.1 or 2.0 stereo and check that the option to invert center/subwoofer isn't selected (or if it isn't try selecting it)
Good luck.
Posted on Apr 05, 2011
  • 1 more comment
  • stivi_8 Apr 05, 2011
    Nah .. the boofers is huming even when its not connect to something (only to the power cirquit ..)
  • martin-r
    martin-r Apr 05, 2011
    ok, a few more possibility's...
    is the volume on the speakers/sub very high and the volume on the pc is being used as master volume?
    Is the amp for the speakers (usually in the sub) located near another power source like the psu for the pc or an appliance? try moving it away from anything with power in it as electromagnetic interference could be the cause, try to locate it at least 2 feet from anything including the floor (could be cables in the floor)
    Other than these possibility's, I would suggest investing in new speakers.
    These are great - I have some...http://cgi.ebay.co.uk/Creative-5-1-Surro...
  • stivi_8 Apr 06, 2011
    tried everything u said ... but maybe i have to give up and go for new set :(
Altec lansing vs4121 speaker boom sound
you may have blown out the speaker or there is a miscommunication between the laptop and the woofer
Jun 15, 2012 | Altec Lansing VS4121 Speaker
What do i hook the sub woofer to
the sub woofer speaker should be connected to the Center, the main speakers should be set to the front and the secondary ones in the rear....(front = main just in case surround is not on, center = is for that ump / boom sound, rear = that just pass you by (make you look behind yourself)
Aug 30, 2010 | Yamaha RX-V659 Receiver
MAKES LOUD HUMING SOUND WHEN VOLUME IS TURNED UP
check out your power point,, there must be sparking in the plug,,, make it fix tight,, the problem will not occur
Mar 28, 2010 | Sirius SUBX1 Universal Plug and Play Boom...
Hello, I own an LG42PCSD,good picture, but, i am
Sometimes the transformer on the Z-Sustain board can vibrate & give off a high pitch noise or hum, or the tranformers on the power supply, I've even known the plasma screen itself to cause a hum. The best remedy is to try & locate exactly the area of the hum to pin point which board is the cause & then replace the board or if it is the screen, then it is more economical to try & put up with the noise rather than replace the screen.
Jan 08, 2010 | LG 42PC5DC 42 in. Plasma HDTV
Loud boom when going in standby mode.
i would check your sub connection also make sure the volume isnt set to high. sometimes unplugging the power and cables also helps
May 20, 2009 | Eltax Atomic A-8.2 Subwoofer
Amp not working properly
yes that is the cause sorry..i have done it before when i was younger a few times thats how i know..sorry man
Dec 05, 2008 | Car Audio & Video
Surround sound
please confirm the  cables between speakers and main unit-no open circuit or broken jack or connector-repeat your speaker setup and confirm that rear and woofer are in on status,
Jul 27, 2008 | Audio Players & Recorders
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
H700
yes, I know the exact problem....The boom mike is a little loose at the swivel. Once it gets loose it does exactly what you are describing. Once it becomes loose like that it's kind of annoying but still usable. You need to squeeze the headset at the pivot.
So you open the boom and squeeze the pivot right in the middle. (One finger right in the middle of the pivot and the other finger on the outside of the headset by the buttons) you will feel it move just a hair and everything starts working again.
After a while you have to do this squeeze every time you open the boom.Let me know how well this works
--john
Jun 29, 2008 | Motorola Mobility H700 Wireless Headset
Power up boom
The turn-on "boom" is caused by the amp getting the remote turn-on signal too soon after the head unit turns on. Most amps need a bit of a delay between them for the internal circuits to stabilize. Some amps have a built-in muting circuit that creates its own delay, but some do not. It looks like you have one of two options:
  1. Buy a pre-built delay module, like these ones.
  2. Build your own delay circuit with instructions from here.
Hope that helps!
Feb 24, 2008 | Clarion APX201.2 Car Audio Amplifier
Philips (DBMMS460) Computer Speakers Logo
93 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
