Question about Southbend 460DD-2TL Gas Kitchen Range
Southbend 460DD-2TL Gas Range can this stove be converted to propane thanks Jeff
  • 4,323 Answers
Hi
Yes it can be converted, conversion kits are available which come with instructions on how its done. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 06, 2011
460DD Southbend Range conversion kit to lp,
Sorry we do not have this information and we do not sell parts.
Feb 22, 2017 | Southbend Kitchen Ranges
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
Southbend 460DD-2TR no pilot after replacing safety valve/thermo couple
Sounds like if you are not getting any kind of flame your pilot assembly will have to be taken out and cleaned. Your pilot orifice is clogged up with build up. Will need a screwdriver, 7/16 wrech and or a 1/2''.
Jun 30, 2012 | Southbend 460DD-2TR Gas Kitchen Range
The gas orfices were changed to propane from natural gas. What size of gas orfices does this oven require? Or will any licensed gas fitter know this and have them on hand to convert this oven back to...
Sorry to read about your problem, I hope this helps you out.
you will have to contact southbend for that info..it is not a common practice to convert these units.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Southbend SLGS12SC Gas Single Oven
HOW TO CONVERT IT TO GAS PROPANE?
Your propane supplier can re-jet your stove to accomodate propane. Give them a call ... they will probably do it for little or no charge.
Jul 06, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Can a kenmore gas stove be converted to propane
Yes.
If you have the owners manual it may tell you the location of the conversion parts that are probably included with the range.
Mar 12, 2009 | Kenmore Kitchen Ranges
The southbend 436d range gives a yellow flame at the burners
Hello. Please advise if your unit is supposed to run on propane, at the bottom of the oven door is a smaller panel, depending on age, it either lifts slightly, and then folds down, or clearly has screws on the front. Your Model/rating plate is behind this, either on the back of the panel, a tag screwed to the frame, or on the bottom ledge of this area. It should state what gas the unit is meant for, propane or natural. If it was not converted to run on propane, or made to run on propane, this is your problem. If it was built/converted for propane I would suggest you contact your propane supplier, or a restaurant service company to look at it, it would require a few specialized tools, pressure testing, orifice size req., and burner BTU. to go much further than cleaning the dust out of the burner, and cleaning the orifice.
Hope that helps, and thank you.
Feb 12, 2009 | Southbend 436D-2GR Gas Kitchen Range
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Southbend 460DD-2TL Gas Kitchen Range Logo
238 people viewed this question
Top Southbend Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Southbend Kitchen Range Expert? Answer questions, earn points and help others
