Question about ASUS P4S8X Motherboard
Hi my AGP WARN lignt is on. Cant start the computer, what can i do?
  • David Petry Apr 05, 2011
    Will it start in safe mode?
    Scholar:
  • 91 Answers
Obvisouly you have problem with your graphics card
if you have onboard video, plug your cable into that for now
open the case check that the fan spins on the gfx card
otherwise its faulty
you will need a new gfx card
Posted on Apr 05, 2011
My Shuttle AV49P motherboard would not bootup. The system is powering up, & the drives are spinning up. There are no beeps & no infor on the monitor. Monitor is working, AGP Graphic card is...
You should get one bios beep. You seemed to have tried everything except a different hard drive. Check the capacitors to see if they busted open. Other than that the motherboard could be fried. Hank
Aug 18, 2010 | Shuttle AV49PN Motherboard
Can we replace the video card in the emachine T3265?
Yes, the computer comes with 1 agp 8x slot available. You want to look for video cards that are agp and 8x. Here's google's results for shopping for an 8x agp. When you get one, you will want to install it. If you haven't installed a component before go to HERE. and download the manual it will instruct you on how to open the case, but it won't tell you how to install the agp card. The expansion cards are the white plastic buses that face the back of the computer. You'll have to unscrew the one metal cover to allow the card to extent out to the back, and you will put the agp card in the brown bus next to the white ones. Don't put in the white ones, those are pci ports not agp. Once you get that done, make sure you screw the card down with the screw you took off the metal cover-plate, and then start the computer and put the cd rom in the drive. The rest it will walk you through.
Good Luck.
Mark
Mar 11, 2010 | E-Machines T3265 PC Desktop
Agp graphics card?
newegg.com
tigerdirect.com
Jan 14, 2010 | EPoX EP-8KRA2+ Motherboard
Red lignt is flashing - advice on how to unclog coffee grinder?
Hi If you have not pushed the coffee button since this happened you can turn the big knob in the bean hopper to the largest # and then turn the small knob to the minus, and try again. If it clears do a second coffee. If it doesn't your going to have to clean the grinder.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Cant log on xp.
hi..if u want to run as good that VGA u need to set in the Bios as init fist display as AGP then find what AGP size appear on bios..if this all OK try to booting the system..thanks and Good Luck..^_^
May 11, 2009 | NVIDIA GeForce 5500 / 128MB DDR / AGP 8x /...
Quick help
nope it cant...it may or maynot support the AGP card but it will not support the geforce currently available...
pls rate...cheers..
Jan 07, 2009 | MSI 865GM3-LS (MS7043020) Motherboard
Hi i have big problem with my ViewSonic VX2235wm monitor
check did you insert external display card or using internal if not inserted then internal display card will not support above 600x800 if you want to work with high resolution then insert AGP card and reinstall drivers there are 4 type cards 1x,2x,4xand 8x you use 8x AGP card then select high resolution also you can look best movie and good support to 3D games
Nov 18, 2008 | ViewSonic VX2235WM Monitor
Cant Start
Take the side off the computer and remove and reseat the memory, if you have two memory sticks try one at a time,also remove and reseat the Graphics card(if one is fitted)as the second long beep depending on the motherboard indicates a memory or graphics card fault. If there is no graphics card fitted (card which is seperate to the motherbaord fitted in a brown AGP slot), then you have an onboard graphics problem. To get around this you will ned to purchase an AGP graphics card and dissable the onboard graphics in the bios (f2 or Del on startup) and in advanced settings set your AGP card as the primary graphics controller
Feb 17, 2007 | Acer Aspire T135 PC Desktop
ASUS P4S8X Motherboard Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
