Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
How do i remove the motor from my relatives hotpoint aquarius wd 64 washer dryer,i removed the front bolt that holds it on and the adjusting nut, but there is a pin and plastic bung that won't shift,this motor is on the top of the machine do i have to tap the pin through if so which way to i knock it through
  • freddiebudd Apr 05, 2011
    i had to tap the pin back through with a rod and hammer to get it off being carefull not to shear the mounting lug but i thought there might of been an easier way it took me and my brother in law 3 hours to remove it and change brushes when it should of only took 15minutes, not happy
    Brigadier General:
  • 6,277 Answers
You might find that it is not a pin but a support which is part of the motor's casing which in turn is fitted into the plastic-lined hole. The motor is able to be rotated for adjustment by it. Try twisting the motor around and it should become free to then PUSH with a blunt object at the same time PULLING the motor out (probably backwards) carefully ;-0)
John C
Posted on Apr 05, 2011
  • john_cross Apr 06, 2011
    I think there are lots of people out there who are not happy with their washer's manufacturer and at least I was able to explain to you how it is mounted! The only 'easier way' would have been if the manufacturer had greased the shaft before fitting for the benefit of people like us - had similar problem with our 19+ year-old Bosch but I then greased ours before putting it back ;-0)
    John C
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
My brushes on my aquarius wma54 need replacing,where is the motor and how do i change the brushes.what type of motor is it
The motor is located at the bottom rear of the washer.
Remove lower rear panel, unplug lead into motor,, remove earth wire.
Remove 2 bolts holding motor to drum, lever motor away from you to remove.
Brushes are located at the end furthest away from the pulley.
There has been more than 1 type of motor fitted to this model, so until you remove the motor, you will not know which brushes you need.
Nov 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wd420 cannot stretch drive belt on there is no slide bar on motor which is fixed solid even after bolts are lossened its a washer drier no obvious way of attaching belt
There is no adjustment provided for tensioning belt as it is a stretch belt.
Best way to do it is to remove the rear panel, tilt the weaher forwards, get someone to hold it for you.
Put belt round motor pulley first, then slowiy feed it round the drum pulley, turning the drum pulley at the same time, it will be very tight, so watch your fingers, just keep going until belt is on, if it comes off, just start over
You can line it up properly in the motor pulley grooves once you have got the belt on.
Please rate my solution.
Thankyou.
Feb 25, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
How do i tighten the drum weights on my hotpoint
Remove rear cover, and you will see the concrete weight at the bottom, sometimes the securing nuts work loose, or break off.
There is also a concete weight in the top of the washer as well,so check this as well
Feb 04, 2010 | Hotpoint Aquarius WD640 Front Load...
How do you remove the brushes from the motor?
You need to remove the lower rear cover of washer.
Remove the drive belt.
Unplug motor lead, and pull off earth wire.
Undo 2 bolts securing the motor to the tub.
Lever back the motor, and keeping a grip on the motor lift out of washer.
The brushes are located at the oppisite end to the pulley, they will probably be enclosed in black plastic holders, but you cannot mistake them, as they each have a wire going to them.
Hope this helps.
Dec 14, 2009 | Hotpoint Aquarius WD640 Front Load...
Am trying to replace the belt on a hotpoint aquarius wf240 washing machine. I have removed the 2 bolts which appear to hold the motor in place ( 1 bolt on each side). However the motor still will not
Hi. The motor is non adjustable on this washer. Tilt washer forward, get someone to hold it steady, and put belt round motor pulley first, then slip belt on drum pulley, and slowly turn drum by hand, feeding the belt on as you turn drum, be careful not to trap fingers, as it is very tight, this is normal, as the belt is a stretch type, this is the reason the motor is non adjustable. Please rate my advice. Thanks.
May 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd420
your drive belt runs from the elec motorpully and then round the drum ?? so if yo look at the motor you will see it resembles rather like car alternator ?? and is fitted with a method of adjustment much the same ie a slide adjust bracket ? which you will slacken bolt/nut to enable motor to slide to a point enabling the fitting of belt? then with a suitable imlement? swing(lever )the motor till belt is taught and re tighten adjust bolt/nut also check the pivot mounting bolt/s/nuts are tight hope this helps
Oct 24, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WD 440
FIRST OF ALL THE PERSON WHO INSTALLED THE MACHINE SHOULD HAVE REMOVED THE TRANSIT BOLTS YOU MAY BE LUCKY THAT ONE OF THE SHOCKS MAY HAVE COME OUT OR A SPRING MIGHT HAVE BROKEN
Jul 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
29 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
