Question about Adidas A164 Sunglasses
The clear plastic connector joining the lenses frame to the arm(the part that goes behind your ear) has snapped off on the right side(left side is ok).What can be done?
  • 8,197 Answers
You can contact the link below to see if they can help you fix your glasses.
http://www.sunglassreplacementlenses.com/
Posted on Apr 09, 2011
How do I remove the front driver side power window switch on a 2008 Buick Enclave
Armrest Door Pull
Remove Rubber Cover
Remove 10mm *****
The first step is to pry out the plastic trim plate behind the chrome colored door release handle using a small flathead screwdriver.Then remove the 10mm ***** behind the plate using a ratcheting wrench with an extension bar attached.
Next pry out the rubber cover at the bottom of the door pull located in the center of the arm rest. Use a Torx T-25 (star bit) screwdriver to remove the two screws.
Remove Torx T25 Screws
2 T-25 Torx & 1 10mm *****
Pry Up Arm Rest Panel
Use a flathead screwdriver to pry up the rear of the plastic arm rest panel. There is a plastic hook at the front of the panel, so only pry it up from the rear edge.
Lift Rear End First
Plastic Hook At Front of Panel
Power Window Connector
After you lift out the arm rest panel, you'll need to disconnect the power connector for the window and door lock switches.
Push Connector Release Tab
Power Connector Unplugged
Two More T25 Screws
Push on the release tab with a flathead screwdriver and pull out the power window / door lock connector.Use a Torx T25 screwdriver to remove the two screws located below the arm rest panel.
Remove T25 Torx Screws
Outer Edge of Panel
Push In Center of Fastener
Then move to the outer edge of the door panel and locate the two small round fasteners. Use a small screwdriver to pop in the center pins of the two fasteners.
Pull Out Plastic Rivet
Black Plastic Fastener Removed
Remove Lower Fastener
Pull out the two plastic rivet fasteners and set them aside in a safe place.
Pull Panel Away From Door
White Plastic Pop Rivets
Pull Off Sail Panel
Grab the door pull in the arm rest and tug it towards yourself to disengage the pop rivet friction fasteners that hold the panel to the door frame.Move to the top corner of the door panel and pry off the triangular "sail" panel. On some vehicles, the sail panel contains the tweeter speaker.
Lift Panel Off Door Lock
Pull Out Door Pull Cable
Lift the door panel off the door lock button and tilt the top of it out towards yourself.Use a pair of needle nose pliers to gently lift the metal ball at the end of the door opener cable out of the mechanism.
Disconnect the door cable from the back side of the door panel.
Door Pull Cable Removed
Disconnect Power Mirror
Then disconnect the power connector for the side view mirror by lifting up on the release tab. Slide the power connector off the plastic anchor on the metal door frame.
Slide Connector Off Anchor
Unlock Connector
Connector Detached
Look behind the door panel and locate the large wire connector with the pink lever lock. Swing the lever open to unlock the connector and separate it from the socket.
Door Panel Removed
Power Window Motor
10mm Bolts
Now the door panel can be completely removed by lifting it up and off the door frame.To replace the power window motor, remove the 10mm bolts.
Stock OEM Door Speaker
Remove 7mm *****
The stock "OEM" speaker is held in place by a single 7 mm *****. Remove it with a socket and ratcheting wrench.
Pry Off OEM Speaker
Speaker Removed
Disconnect Power Plug
If the speaker is stuck to the door frame, gently pry it off with a small flathead screwdriver.Disconnect the speaker's power plug by pressing the release tab with the small flathead screwdriver.
Fits 5.25", 6.5", 6.75"
Re-installing Door Panel
According to the Crutchfield website, the 2008 to 2012 Chevrolet Malibu's front door speakers can be replaced withaftermarket speakers in the following sizes: 5 1/4", 6 1/2" or 6 3/4" speakers with the use of a bracket.If you'd like to reduce road noise, make your car quieter and also improve the sound from your speakers, I'd recommend applying some Dynamat Sound Deadener on to the metal door frame.
Re-Attach To Anchor
Plug In Power Side View Mirror
Re-Insert Power Connector
To re-install the door panel, first hold the panel close to the door frame before re-connecting the large wire plug. Swing the pink lever closed to lock it in place.Slide the socket for the power side view mirror back on to its anchor and insert the power plug.
Lock Power Connector
Pink Lever Locked
Re-Insert Door Pull Cable Ball
Insert the metal ball at the end of the door opener cable back in to the door handle mechanism.Slide the black plastic cone part of the cable back into the slot in the door opener assembly.
Door Opener Cable Reinstalled
Hang Door Panel On Frame
Gently lower the door panel down on to the edge of the door frame with the door lock switch through the opening at the top.
Line Up White Plastic Fasteners
Push On Sail Panel
Push Door Panel In Place
Move to the bottom of the door panel and line up the white plastic pop rivet fasteners with the holes in the metal door frame.Push all around the door panel to re-insert the pop rivet fasteners.
Re-attach the sail panel at the top corner of the door frame.
Push Panel Flush Against Frame
Insert Side Edge Fasteners
Insert Larger Piece First
Next move to the side edge of the door panel and first re-insert the larger piece of the two fasteners. Then insert the smaller "pin" piece of the fastener into the middle of the larger piece.
Insert Small "Pin" Piece
Install Lower Edge Fastener
Tighten 2 T25 Torx Screws
Re-Attach Power Connector
Insert Front Hook First
Insert and tighten the two Torx T-25 screws located under the arm rest.Re-attach the power connector to the plastic arm rest panel.
First insert the hook at the front of the arm rest panel and then snap the rear end in place.
Pop Arm Rest Panel In Place
Tighten 2 T25 Screws
Replace Rubber Cover
Insert and tighten the two T25 Torx screws into the door pull cup. Then replace the rubber cover over the two screws.
Tighten 10mm Door Handle *****
Replace Door Handle Trim Plate
Malibu Door Panel Replaced
Replace the 10mm ***** that goes above and behind the door opener handle and tighten it. Pop in the plastic trim plate behind the door handle.
Apr 10, 2016 | Buick Cars & Trucks
I have a LG GRL207QVJA Fridge Freezer and have a leak behind the water dispenser. How do I remove the control panel to get behind it so that I can replace the leaking tube?
Hello Adrian;
My name is Peter. I am a retired field service refrigeration technician.
You must be in the UK. I can not pull up any information on your unit, but I will try and walk you through this.
Hopefully the water leak is directly behind the dispenser. If you have water leaking out the bottom of the door, then you are going to have to replace the whole door. It water is leaking out of the bottom of the door then the insulation in the door is saturated. Over time the water in the door will freeze and crack you door liner open. There is no way to dry the insulation out. So, lets say this is not the case.
You either have a contact pad or a paddle arm in your dispenser housing. You may have a plastic curved piece at the top of the dispenser housing. It is held in by plastic clips. Squeeze this on both sides to release.
Up plug the refrigerator. Their are electrical components behind this housing. On the bottom of the housing frame are 2 small slots. With a flat head screw driver, pop the bottom of the housing out. On the sides and top of the frame are plastic clips. Push in on the sides of the frame to release. If you have a control board on the top back of the frame - remove the connectors. They are idiot proof. Each connector is designed to only fit a special plug. Set the frame assembly aside. You may have to remove a control board fixed to the housing, A contact switch housing and the housing itself. There are screws that go around the housing frame for removal.
On the bottom of the door there is a spring and a tubing connector. Push in on the end of the connector to release the tubing. You may have to remove a black locking ring on the connector first.
The tubing assembly you are replacing is available as a part.
Here is the hard part. Using a good adhesive tape, tape the top end of the new tubing to the bottom of the old tubing. Feed the tubing up from the bottom.
If you do not have slots on the bottom of the frame, you must push inward on the frame to release the frame from it plastic retaining clips.
Peter, Baltimore, Maryland, USA
Oct 31, 2014 | Refrigerators
2002 fxdl no power white wire high beam indicator on dash indicates high beam is on still no power
Well, electricity is electricity and wiring circuits are wiring circuits. I do not have a 2002 fxdl electrical service manual either so cannot help there. On a 2003 the white wire goes from the headlight to four pin connector 38B and from there to four pin main harness connector 38A pin 2 and from there to connector 20A pin 4 and from there to (fxdl only) connector 21A pin 2 to connector 21B pin 2 to high beam indicator light which has BK wire ground going to 21 B pin 6 to 21B pin 6 after which it joins other BK ground wires to speedo and to 20B pin 12 and then to 20A pin 12 to TS/TSM pin 12 (ground)
POWER from ignition switch into lighting 15 amp fuse by connector 38 pin C R/BK and out from fuse by BE to connector 24A pin3 and out connector 24B pin 3 BE into handlebar switch then out from handlebar hi/lo switch into connector 24A pin 4 W and then out from 24B pin 4 W to connector 20A pin 4 W (which joins to speedo connector 20B W and also goes to connector 38A pin 2 W which goes to 38B W pin 2 to the headlight high beam element on the right side pin with the low beam element connection on the left side (on the wiring diagram) (Ground wire is also on the (diagram) right side and goes also to HDI position lamp is on the bike and HDI position light power is from connector 38B pin 1 O/W etc.
Connector 20 is a 12 place Multilock is console gauges connector located under the console on fxdl
Connector 21 is a 10 place Multilock console gauges connector located under the console on fxdl
Connector 24 is a 6 place Deutsch left hand controls and horn connector located on the frame backbone
Connector 38 is a 4 place Multilock headlamp connector located on the frame backbone
Jun 19, 2014 | Harley Davidson Motorcycles
2000 grand marquis driver's side windshield wiper lifts off windshield
Hello Steve,
From your post, "Finally had enough and stuffed a small block of wood between the driver's side bottom of the molded plastic linkage frame enough to lift the whole thing enough to put a moderate amount of pressure behind the wiper blade..", it sounds like this box is warped or somehow out of alignment. Is it possible for you to buy this box from a wrecking yard? Has you car ever been in a collision? If so the frame may have so un-repaired buckling resulting in the misalignment.
Mar 10, 2017 | 2000 Mercury Grand Marquis
How to replace the lenses for oakley spike
I did the following... step by step, if you have any questions, please ask. - I placed the sunglasses perpendicular to me. One if the lenses will be close to you, while the other should be farther away.
-I grabbed the farthest lens from your body with both hands. Placing your left had on the left side and your right and on the right side. One had is on the bottom of the lens, while the other is on the top of the lens. It does not matter which hand is on the bottom or top.
-I grabbed the top and bottom of the frame, pulling away from the lens. At the same time I pushed with my fingers (that should be on the inside of the lenses) and pressed the lens out (on the lens closest to the nose pieces). You will hear a very faint "pop" when the lens clears the frame.
-Then slide the lens out by grabbing the part that is out of the frame that is close to the nose piece
-To put the new ones in, position the sunglasses the same way and put the replacement lens in the sunglasses, starting with the edge near the ear pieces.
-Pull the top and bottom of the frame out and push the replacement lens into place.
If you have any questions, please ask. If I can clarify anywhere, let me know.
Good luck.
And once you do this,could you please leave me feedback and vote on my answer?
Thank you very much,
Lori
Mar 17, 2011 | Oakley Spike Sunglasses
Where is the fuel filter on 2005 mercury mountaineer
It's behind the back right tire if I remember correctly. you have to have the car lifted to get to it. It is mounted directly in front of the fuel tank, on the passenger side, there is an aluminum heat shield with (3) 13mm bolts that need to be removed, then there is a plastic shield with (2) 10mm nuts that needs to be removed, the fuel filter can then be removed, it snaps into a bracket that is secured by the same (2) 10 mm nuts holding the plastic shield.
Thank you for using fixya and be safe.
Jun 09, 2010 | 2005 Mercury Mountaineer
I need to install a new ignition coil in my 1998 ford windstar. How do i do this?
You can sometimes (if you have 2 elbows on each arm) reach around the back of the intake manifold and replace the coil pack using a 1/4 inch rachet with a 7mm socket.
Most of the time you need to remove the plastic cowl assembly located under the windshield wipers. To do this remove both wiper arms by lifting the plastic covers at the bottom of each wiper arm. Remove the 15mm nuts that hold the wiper arms down and wiggle the arms while pulling upwards until they come off (take note of which is left and right, they are different sizes). Next remove the plastic phillips screws/ plastic rivets that hold the cowl down on the bottom towards the engine(the screw comes up half way and when you pull up the base/ rivet comes up with it).
Next pull up on the cowl where it meets the windshield left or right side and you will hear the retainers snap and release. Continue pulling until the cowl is loose. Next disconnect the hoses that go to the washer nozzles. Put the cowl aside.
Next remove the micron filter located on the passengers side of the cowl (if it has one it is a good time to replace it). Remove from left to right 8or 9 8mm bolts that hold the lower cowl down. On the drivers side disconnect the 8 pin connector for the wiper motor. Now disconnect the washer fluid hose that goes thru the cowl on the passengers side. Lift up on the cowl and you should be able to wiggle it out and set it aside. You can now see the coil pack behind the intake manifold. Take note of spark plug wire location on the coil pack because they have to go back on in the same order.. Reassemble in reverse order. Note that while the cowl is off it is a great time to replace the spark plugs on the back of the engine.
Good luck to you and congratulations for doing it yourself
Apr 04, 2010 | 1998 Ford Windstar
Exterior rear door handle on Honda Accord 2001
To Remove Door Panel on 2001 Honda Accord:
A: To remove the plastic piece with the door lock button and door handle connected to it:
1- Remove the screw in the middle located behind a plastic cover button
2- Push (slide) the whole assembly Forward (toward front of car)
Besides the screw, it is held in place by 3 hooks on the backside that hook into holes in the metal door frame
3- Now unhook handle from small metal bar going through door by pushing (toward door) plastic clip (blue?) off of the bar, then the bar will come out of the clip hole, thus releasing the handle.
4- Depress little grey button /bar (purple painted on it)on elec. connector to seperate connector, thus releasing door lock switch
Now the whole assembly (metal handle, door lock switch, and plastic piece) will come off door panel
B: The door is held on by 2-screws, 7-plastic snaps/plugs, and 1-plastic plug.
The screws are located: bottom of hand hold and the other behind the handle, both covered by little covers that have to be pryed off to access the screws.(hint: the screw with the built in spacer goes behind the handle when you are trying to reinstall)
The 7-plastic snaps: 3 across bottom and 2 on each side. Not visible, they are mounted to the inside of the panel.
The 1-plastic plug is visible at the upper front of the panel and is the same color as the surrounding trim
C: Take off the big plastic triangle piece above the door panel and behind the mirror. Pull/pry off. It has 2 snaps holding it on. one near bottom and one near the front.
D: Light lens prys off from bottom. Unscrew (1/4 turn) the light assembly with bulb still intact from backside of panel
E: Remove the Hand-Hold/window switch assembly:
Jan 14, 2009 | 1997 Toyota Camry
Error 13.20.00
There is a paper feed sensor located behind Tray 1 where the tension spring gets knocked loose, therefore the sensor arm is still blocking the sensor. You have to remove all covers and the Tray 1 Assembly and re-install the spring which goes into a slot on the plastic frame.
Apr 11, 2008 | HP LaserJet 4350 Printer
Lenses
The screen with the "swirls" on it is the fresnel lens and that is the one that goes in back then the lenticular lens goes next (it has the feel of a grid to it). Then the screen proetector goes on the very front. The fresnel lens only works installed one way. On Sony TV's look for the orange tag with the part number on it and put that to the lower right facing outword and usually 99% of the time this is how they go back in.
Feb 18, 2007 | Sony KP-51WS510 51" Rear Projection...
Adidas A164 Sunglasses Logo
203 people viewed this question
Top Adidas Clothing Accessories Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Da Doc
Are you an Adidas Clothing Accessory Expert? Answer questions, earn points and help others
