Question about Smeg Linear Pyrolitic Single Oven Electric
Unable to loosen bulb from my teba oven , don,t know if to unscrew or pull ?
How to unscrew bulb cover in AEG oven? Glass cover won't move!
spray with oven cleaner leave for a day then try again
Apr 30, 2015 | AEG Ovens
Lamp Holder
It has to be reinforced
Jul 25, 2012 | Neff Ovens
I have a Bosch HBN double oven unit. The bulb in the lower oven has broken with the screw-in base of the bulb stuck. The glass top of the bulb has come away. Cannot get the remaining bit unscrewed due to...
If you try using a thin NOSE PLIER - with a n ALIGATOR MOUTH- it will be easy to pull out by unscrewing the stuck up damaged thread of the bulb. Once it i s free even with a higly pointed screwdriver it can be pushed to unscrew.
Please try this out and it will be easy to replace.
Aug 19, 2011 | Bosch Ovens
We are trying to replace the lamp in our Bosch Double oven but are unable to unscrew the lamp cover. The oven is very new but the Manufactors service agents dont want to know. Any guidance would be very...
Hello Graham,
The lenses unscrew anti-clockwise, but they can be very stiff and difficult to grip. The best advice I can give you is to double or triple wrap a thick elastic-band around the lens as this will give you much better grip than you will get on the glass alone.
If you are still unable to unscrew the lens, squirt a small amount of WD40 / penetrating fluid down the back of the lens so it runs onto the threads and leave it for 15-20 minutes then try again with the elastic-band grip. Once the lens moves a small amount it will unscrew relatively easily. The constant heating and cooling of the oven causes them to lock.
Please switch off the power supply to the oven before replacing the bulb and make sure you have clean hands when replacing the bulb - grease from your fingers can cause the bulb to fail or shorten its life considerably.
Hope this helps. If you are still unable to unscrew the lens, please let me know.
Regards,
BElectric.
Apr 12, 2011 | Bosch HBL 5056 Electric Double Oven
Where can i get a manual for a built in teba fan oven. It has reset itself and the timer switches off after 2 minutes and I cannot reset to not use the timer so cannot cook anything in the oven.
Try pressing the stop/cancel button, this should clear the error, if this does not work unplug for 5 minutes and then plug back up , this should clear the display and the oven should work.
Nov 14, 2009 | Ovens
Unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Jan 12, 2009 | Ovens
Unable to take out light bulb
I can tell you it screws out . i had to break mine to get it out ( the bulb cover that is) Still had some thread left to wind back up.
Dec 22, 2008 | Ovens
Light bulb
for most smeg, the bulb cover just unscrews as does the bulb and the bulb is a heat-proof small edison screw type
May 07, 2007 | Smeg SE250XUK Stainless Steel Electric...
Smeg Linear Pyrolitic Single Oven Electric Logo
119 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
