Question about Fuji FinePix Z10fd Digital Camera
My Fuji camera says that my 2 Gb SD card is protected. I can do anything with card (open photos, copy, delete, format card) on PC, but cannot do anything on camera. Please, HELP!!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Dec 29, 2012
  • kakima Dec 29, 2012
5 Suggested Answers
dlundmark
  • 797 Answers
SOURCE: cannot download pictures to my computer from my fuji sd card
hecht:
If you are trying to download to a computer, then make sure you are not trying to go to a cd.
Try to write to the dr4 (not sure which one this is) with out the camera connected. If you can write to the hard drive with not problem, then try the following.
Make sure you are not trying to write to the camera.
Remove the card from the camera, and use a card reader.
Posted on Aug 09, 2008
  • 110 Answers
SOURCE: Fuji Finepix A820 camera. Videos and Photos are not all viewable on PC
Sounds like the card is corrupted
First save all your pictures to your computer.
The first step you should try is to try reformatting the card using the menu options on your camera. YOu should still be able to access those options
Posted on Aug 23, 2008
  • 11967 Answers
SOURCE: Fuji S1500 unable to delete photos after taking
Deleting or formatting on the computer instead of the camera corrupts the card. The camera does not recognize the operating system used to delete. Stop using the computer to do that!
Posted on Apr 12, 2010
15073327
  • 441 Answers
SOURCE: My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
Posted on Nov 29, 2010
How do I delete all photos on my chip
Based on what you have said, it appears that the write-protect has been activated on the card. With the card's label facing you and the corner cut-off to the right, you'll see a little slot just a bit above the halfway point on the card. In that slot is a tab. If the tab is down toward the bottom of the card, it's in the write-protect or locked position. You cannot delete anything while the card is in the write-protect mode. Simply slide the tab to the top of the slot to unlock it and your delete function should work.
If it does not, you've got another problem which you may be able to fix by formatting the card. Once again, you cannot format a card in the write-protected mode.
If you can't format it...which will delete any pictures on the card... then the card is probably bad and should be replaced. Cards are cheap and really not worth spending a lot of time trying to solve the problem.
If you can't format a new card, then you've got a camera problem and it's time to call or contact Nikon support.
Feb 12, 2015 | Nikon D5000 Digital Camera
How to put photos onto SD cards
In Windows, click on Start/Computer. A window opens showing all the drives connected to the computer. Under "removable drives" locate the SD card. Hover your mouse pointer over the SD card icon and it should tell you how much free space is on the card. If necessary, delete some photos or other data to make more space available so you can add the photos you want. If there's already plenty of space, try formatting the SD card in either ex-FAT or NTFS format. Then try copying the photos again. If the SD card does NOT in appear in removeable drives then the SD card may be faulty. Try a different SD card.
Nov 04, 2014 | Philips 6.5-Inch Digital Photo Frame...
SAMSUNG D760 HOW TO DELETE PHOTOS, IT SAYS CARD LOCKED.
May 19, 2014 | Cameras
Recover pictures formated
Recommend you read 'recover deleted files from SD card'
it will tell you how to recover data from SD card step-by-step.
Aug 06, 2013 | Video Cameras
I've deleted my photos by accident from my Canon ixux 200 IS - by pressing the format button by mistake- how can i get them back again. Thanks verymuch
I have had success with this... Download the program
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Mar 16, 2011 | Canon PowerShot SD980 IS / Digital IXUS...
What do I have to do if the camera says crad protected and won't let me take or delete photos?! It let's me look at the photos and I can't delete them! I put the blue 1 GB chip in the computer yesturday...
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 23, 2010 | Fuji FinePix F45FD Digital Camera
Protection problem
Easy solution:
1) Put the sd card into your computer
2) Copy all the photos to your computer. User Windows Explorer to just drag the folders from the card.
3) Format the card
If you insist on having the photos back on the card, then just copy them back to the card using Windows Explorer reversing step 2.
Aug 26, 2009 | Sanyo VPC-E760 Digital Camera
Fugi S5000 2gb xd M+ Computer says it's not formated
Yes, it would appear that you solved your own problem. The Fuji S5000 apparently only takes the max of 512 mb card. I own a newer Fuji S700 and it works fine with a 2 gb SD card, but I haven't tried anything bigger. Your best bet is to see if you can exchange those 2 gig cards for 512 mb cards at the store where you purchased them, and then try the 512's to see if your pc will read the pics. Explain to the store what the problem is and they should allow you to make the exchange.
Aug 06, 2009 | Fuji FinePix S5000 Digital Camera
Format and Check SD card
Purchase an inexpensive card reader such as the Ativa, available at Staples and Office Depot for $9.95. Put your memory card with the photos on it into the reader and plug it into a USB port on your computer. Windows will recognize it as another drive and assign it a drive letter. Using any graphics program, or Windows Explorer, navigate to that drive, open the file containing the pics, click select all, and copy the pics to a file on your computer. Make sure that all the pics have transferred or copied to the new file. Replace the card back into your camera and format the card so it is empty and ready to receive new pics. FYI: Less than 1 gig memory cards are available on ebay for dirt prices. Also, go to the camera manufacturers website and see if they have a firmware update for your camera that allows larger than 1 gig cards to be used. I had to do that for my Fuji S700 so I could use 4 gig cards. It used to max out at 2 gigs. If this has solved your problem please rate it accordingly. Good luck.
Jul 05, 2009 | Samsung Digimax S800 Digital Camera
How can I delete write-protected files in pen drive
my multi-card (SD) kingston 2 GB is unable to copy , delete and format. It is always say that your multi-card is write-protect. I try to delete some file on it. It is able to delete but i reconnect to my PC,it shows my previous deleting files. why? If you have time , help me please.
Aug 07, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Fuji FinePix Z10fd Digital Camera Logo
47 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
