As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.? this is for the Panasonic sa-ht 880.
the F61 error on panasonic home theatres can mean 1 of 4 things, its either you have the wrong speakers plugged into the wrong port (yes apparently this matters check correct speaker placement), the fans are not working at all or working poorly (simply clean with circuit board cleaner or replace fan you may have 1 or 2) if none of the above then you have the worst one wich is one of your power amplifier IC chips somewhere on the main circuit board has died (good luck fixing that one) obviously varies from model to model this is based on th SA-HT545 and the SA-PT450. Sometimes a new HDMI cable will solve this issue.
If the cables are good, then the easiest possible fix would be to clean or replace the rear electric fan. I had the same problem and after replacing the fans my unit works like new. I called panasonic to order the fans because these type of fans you can not buy out of any store. The rear fan is also an upgrade to a better bigger fan. Part numbers are: L6FAJCCH0007 $19.12 (side fan) RFKZHT540E $28.35 (Rear fan) total shipped to me was $61.43.
Sorry to hear about your error code F61 This code refers to a High Limit Temp. condition. This is most likely caused by the cooling fan. If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit. Please check the cooling fan, any possible air flow restrictions and correct running RPM. Hope this information has helped you. Readers, please rate your technicians information. Thanks, John Ray [email protected]
i had the same problem with the error code f61.There are 2 fans,1 external and 1 internal and were both working but were very clogged up with dust thus working harder.Try cleaning them both it worked for me on the SA-HT 990 model
