Question about Frigidaire 24 in. GLD3450RD Built-in Dishwasher
Lately the soap remains in the dispenser, dried and caked in (I have to dig it out with a sharp object, as it becomes a solid piece). I have also tried gel soaps, but find them in the bottom of the dishwasher, partially intact. The mistery is this does not happen all the time, but most of the time! I've checked the water pressure and the water temperature: both seem to be fine. The dishwasher does run a full cycle. Is it time to buy a new one? Would you also be able to tell me what year this model is? Thank you!!! Florence
  • Frigidaire Master
  • 1,830 Answers
How old is your dishwasher? That should tell you whether you need to buy a new one. If you still have the manual that comes with it it should tell you what model that is is.
Posted on May 12, 2017
  • 92 Answers
SOURCE: Soap cake not dispensing
it is highly recomended that you use powder detergent only absolutley no blocks or tabs or gels
Posted on Jan 20, 2008
  • 630 Answers
SOURCE: Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Posted on Jul 02, 2009
  • 50 Answers
SOURCE: Dishes on lower rack are not getting very clean,
Check the water intake screen for sediment. Sometimes if sediment partially clogs the screen, the water pressure is lowered significantly enough to cause these conditions.
If you send me the make & model of your DW I'll tell you where the intake screen is. Sometimes its on the bottom which is a pain because you have to pull the DW out of the cabinetry...
Posted on Oct 11, 2009
  • 274 Answers
SOURCE: not dissolving soap
Try cleaning out soap disp. it my be blocked you could be using to much soap.hop this works thanks
Posted on Jul 26, 2010
heatman101
  • 43501 Answers
SOURCE: my soap cup (using gel soap) doesn't empty and
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
gf
Posted on Sep 30, 2010
Where is the soap dispenser and jet dry dispenser on a Danby countertop dishwasher (with window)
I've got one of these countertop washers at home. The twist off dispenser you're talking about is for the jet dry (at least on mine) and there should be an area on the right side of the door for your soap. Hope this helps!
Jan 31, 2013 | Danby Dishwashers
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
The dishwasher detergent dispensor door opens, but it does not eject the detergent into the tub. The detergent cakes, and the dishes remain dirty. Additionally, the dishwasher has become much louder than...
heatman101
Sep 21, 2010 | Bosch 24 in. SHX46A05 Stainless Steel...
I have a old Asko Dishwasher. It works perfectly. However at times at the end of the wash cycle the soap remains in the dispenser. This happens half the time.
Put less soap in. Your wash will be fine with less soap. We have same problem. MARK: do not have tall objects underneath that will stop upper rotor from spinning. Also objects in upper basket kan penetrate and stop uppper rotor from spinning. Using less soap works for us.
Mar 09, 2010 | Asko 24 in. D3450 Dishwasher
The soap dispenser only opens sometimes. When the dispenser doesn't open the soap is in a solid cake inside dispenser.
IF DISPENSER IS CLOSED WHEN FINISHED COMPLETE CYCLE .
THERE ARE TWO WAYS THAT D/W'S
OPEN THE DISPENSER ONE IS BY WAY OF TIMER TRIPPING LATCH, OTHER IS BY WAY OF BIMETAL IN THE DOOR. THE SOLID IS BECAUSE OF THE MOISTURE ABSORPTION OF THE SOAP. THIS IS ASSUMING THAT YOU HAVE NOT BLOCKED THE DISPENSER DOOR WITH SOME OBSTRUCTION.
Feb 18, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
My GE Profile Dishwasher PDW7880 Soap dispenser does not empty
I had the same problem. After some investigation I found that the hose that brings water to the top arm was clogged. There was a piece of chipped china logged in there. I have no idea how it got there as it is at the top and facing the the back wall but once I managed to take it off it solved the problem.
Dec 21, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Could SOAP DISPENSER be caked with soap???
POWDERED DETERGENTS GET CLOGGED ALOT IN THOSE DISPENSERS. I ADVISE CUSTOMERS TO FILL THERE WASHER AND ADD SOAP WHEN IT STARTS TO AGITATE WHEN USING MORE THAN A 1/2 CUP OF POWDER ... THEN ADD YOUR CLOTHES ... THE WASHER HAS A SAFTEY SWITCH WILL STOP MOST WASHERS WHEN AGITATING OR IN SPIN CYCLE,SO YOU CAN LOAD CLOTHES ... OTHER THAN THAT ... ALL YOU CAN DO IS KEEP THAT DISPENSER FLUSHED OUT WITH HOT WATER AFTER EVERY WASH. JUST POUR HOT WAYER TROUGH IT ... IF THE WATER BACKS UP (EVEN WITH A SLOW POURING) THE DISPENSER IS PLUGGED AND NEEDS TO BE FLUSHED OUT WITH A HOSE. GOOD LUCK AND STAY DRY !!!
Apr 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Frigidaire 24 in. GLD3450RD Built-in Dishwasher Logo
47 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
