Question about Canon P1-DHV Calculator
Loading paper. a diagram would be helpful - Canon P1-DHV Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
You'll find illustrated instructions in the manual you can download from the manufacturer's web site at
http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf
Posted on Apr 05, 2011
Hi, my lexmark e260dn "load paper" light stays on even though paper is loaded. please help
Please check if the paper guides on the paper tray are correctly positioned. For example, if you are using a letter sized paper, make sure the guides are set to 8"x11".
Dec 20, 2012 | Lexmark E260dn Laser Printer
Tip
PROBLEM - OUT OF PAPER
If many people are waiting for printouts, and nothing is actually being printed, the printer may be out of paper; the printer will indicate this on its display. To load paper into the N4525 printer, simply pull out the tray #1 or #2 located at the bottom of the printer in the front, and put the paper in the bin. Put the tray back into the printer. To load paper into the N24 printer, locate the tray in the front of the printer. <br />Pull the tray out, and locate the bin indicated by the large arrow in the lower left-hand corner. This is the side where you put the paper. Then, push tray 4 back in to the printer<br />.Make sure you put the paper on the correct side of the tray. This is the most common error. There are usually diagrams on the inside of the trays indicating how to put in the paper.
on Jan 06, 2011 | Office Equipment & Supplies
Hi do i fax with the paper facing up or down?
not sure about this specific model. However, on the loading platen you should see a diagram of a sheet of paper with the top right corner turned over which indicates the paper should be face down. If it doesn't have this diagram you should assume it is face up.
Jul 22, 2011 | Brother MFC-3220C Plain Paper Inkjet Fax
Ink smudge on envelope
dvlknc
The paper thickness lever is not on the front...it is on the floor of the "paper output tray" chamber. It is hard to see without directed light.
Refer to Loading Paper section of the Quick Start Guide....p 15 2 Prepare to load paper
(4) Adjust Paper Thickness Lever
(See diagram)
Or look at the "User's Guide on-screen manual" as directed by the Note on p. 17
I really had to search to find this lever while attempting to resolve my problem with a badly aligned printing head. I am going to have to buy a new printer. It definitely won't be a Canon due to the rip off cost of print cartridges.
Hope this is helpful.
kellyplus
Nov 14, 2008 | Canon PIXMA MX310 All-In-One Printer
Address envelopes correctly
I'm running Vista and I thought there MUST be a way to print envelopes! So, this is how I figured out how to print envelopes perfectly! No doubt, this would be how the manual would instruct, but it's apparent that none of us are able to locate our printed copies, right? Guilty as charged!
Slide paper tray out; remove paper you have loaded in your tray. Set envelope in tray (face down, with top of envelope flush left) and adjust both side bars (designated as "1" in paper tray diagram - visible when all paper is removed from paper tray) so that they are flush against envelope. Slide back bar (designated as "2" in paper tray diagram - visible when all paper is removed from paper tray) so that it is flush with edge of envelope. Click print.
Believe defaults are set to #10 envelope. Envelope options - check / click on the following: face up, clockwise rotation and "Feed from" Auto Select. Click on / highlight the 5th envelope depicted in the top row of envelope examples.
Jun 16, 2008 | Brother Multi-Function Center MFC-240C...
Loose spring on epson c66 - paper loading problem (hardware issue)
Hi-
yep chances are those spring might not be available for replacement, try compass micro visit their web for an exploded diagram of the printer or parts. this is one of their parts distributor.
Hope this helps
Mar 22, 2008 | Epson Stylus C66 Inkjet Printer
Cannot find solution to how to replace paper for the Sharp UX-108 Fax machine
I must have an operation manual so Ican follow instruction and at the same time I will know what is the trouble.
Jan 17, 2008 | Sharp UX 108 Roll paper Thermal Fax
Canon P1-DHV Calculator Logo
233 people viewed this question
old marine
old marine
