Question about Health & Beauty
Rascal 600T motor gets hot. - Health & Beauty
  • 692 Answers
Check the electric brake its most likely not disengaging from the motor case causing the motor to strain and overheat. You can unscrew the brake assembly from the rear of the motor and check to see if the brake pad is free and moveable If you can support the rear wheels off the ground and engage the throttle you should be able to hear and see the brake pad release. You can drive the scooter with the brake off the motor but do not disconnect the brake wiring. The scooter looks for that connection to work if it can't find the brake then it will flash and won't operate. now if you do hang the brake off the motor remember you do not have brakes and the scooter can roll backwards when going up ramps or on hills. You will have to replace the brake assembly and reattach it to the motor to have brakes
Hope this helps you
Posted on Apr 05, 2011
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
LOOKING FOR A WIRING DIAGRAM FOR RASCAL SCOOTER 600T
go to http://www.strege.com/BlueDoc click on rascal then click 600
Aug 23, 2015 | Health & Beauty
Electrical diagram for rascal 600T
check the link Scooter Doctor App check the rascal section
Replacement of rascal 600t headlamp
Hi, To get to the head light bulb you need to take the tiller head apart by removing the screws that go up from the bottom. The top will lift off but be careful not to pull any wires off. This will give you access to the lamp at the front. Make sure you replace the bulb with the same type and voltage.
Jan 13, 2015 | Rascal 600 T Electric Scooter w Seat Lift...
Need a battery charger for rascal 600t
I recommend the 5 amp Charger. Monster Scooter Parts have them.
Apr 09, 2014 | Electric Mobility Power Electric Scooter...
Rascal 600T Scooter FIX IT Manual
There is an owners manual available which has a troubleshooting guide at the following: http://manuals.monsterscooterparts.com/mobility/Rascal/manual-rascal-600-t.pdf
If you have a good relationship with a local dealer they may be able to copy and provide you with one.
Electric Mobility, the manufacturer, in my experience will not provide one to you.
Mar 02, 2014 | Electric Mobility 3 Wheel Motorized...
I have a Rascal 240. The battery charger has blown the internal fuse. It is a GMA but I do not know the proper ampherage to use. The fuse in it was repalced by the person who sold it to me and I
The charger puts out 24VDC@4A. Typically my charger [off a Rascal 600t] will charge at 3.5A. It seems that the industry standard is to multiply the amperage by 135% providing that your using the proper gage wire and the temperature is nominal. 3.5A x 1.35 = 4.73 or 5A. So i think a 5A fuse will do it for you
Jul 16, 2012 | Electric Mobility Mobility Electric Power...
I've recently bought a new tga sonet scooter, it's very noisy, they tell me that they are a noisy scooter can anybody tell me if this is true.
Block the rear wheels up off the floor. Now put the sccoter in gear and let her rip! Is it real noisy? Did they replace the motor or the trans-axle on which th motor is appart of. If they replaced the entire assembly and its still making noise, thats what they sound like. Ive heard some of the scooters make a winning sound. Go to a place that sells this model and compare. My scooter is a Rascal 600t it makes some noise. It shouldn't be too noisy though. Its hard to tell from here.
Jul 12, 2012 | Electric Mobility Health & Beauty
Batteries do not charge but charger is working. Rascal 600T todusty@juno.com
mcdevito75 here, You may need new batteries, if they are 2 years old or more.
Jul 02, 2010 | Electric Mobility Mobility Electric Power...
Health & Beauty Logo
188 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
