Question about Refrigerators
We've just started noticing something that sounds like water is running or trickling inside the refrigerator walls. Nothing appears to be leaking both inside the refrigerator or outside onto the floor and the refrigerator is cooling just fine but this sound of water running between the walls of the refrigerator has us concerned. It is a side by side GE refrigerator. Thanks!
  • 4,059 Answers
It's probably just the freon equalizing in the system after the compressor cycles off. There are probably some freon lines in the wall between the freezer and fridge.
Posted on Apr 06, 2011
Aqualisa aquastream - when I turn it on the water pours down the wall. When turned off no trickle or leaks.
Surely something is leaking. I am attaching a diagram of the parts inside the unit for your reference. See if you can access the parts to find out which one is leaking and replace the broken part.
Feb 16, 2014 | Home
Fridge filling with water
OK usally this indicates that either your defrost drain leading down from the freezer has a blockage of ice, gunk or both. Unplug refrigerator and remove the rear panel inside freezer and on the back wall of many refrigerators.
I noticed you did not post your model number so I have to assume your freezer is on top above the fresh food section? If the water is trickling down the wall inside the fresh food compartment it is possible you have a small bowl that catches the water coming from the freezer and the drain line then turns and leads out of the fresh food section and down the back of your refrigerator. If yours does have that catch bowl this is the likely place for the drain line to get clogged. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrianAnd in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
If the quick movie on You-Tube is not below click HERE
Nov 08, 2012 | Refrigerators
Water does not flow
Sounds like air in the line.....the filter may be cracked/damaged, or not quite seated...?
since you've tried 2 new ones....I'm gonna bet they are not quite the correct ones for your fridge.
Sep 07, 2012 | GE GSHF5KGXBB (254 cu ft) Side by Side...
I have a Kenmore Coldspot Fridge. The icemaker is leaking in the fridge and running water all over the inside causing ice to form every where. I already replaced the water fill tube. I noticed after the...
Yes exactly that is the water inlet valve thats causing that its not fully closing yet its staying open a little and seeping water through it.
GENE
Sep 09, 2011 | Refrigerators
We had a leak and unhooked the hose to the refrigerator. After fixing the leak, we rehooked the hose but we are not getting any ice cubes. The water is getting to the refrigerator because we get water to...
You probably have a frozen water tube - the tube where the water comes out into the icemaker, on the inside. If you had water trickling down that tube due to air in the line then it could have frozen. I've seen this before. Check it out and defrost with a hair dryer if this is the case.
Oct 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Subzero bottom freezer drawer is freezing shut.
Silicone bath/shower sealant should work, the one that smells like vinegar. Also known as RTV.
Just make sure the area is dry, clean and free of old caulk.
It'll need to be at room temperature to set properly for a few hours.
I have used this sealant on things before that went as low as
-50C. Preperation is the key though.
Oct 11, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
193 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
