Question about Dell Office Equipment & Supplies
Hi - we have a Dell 3130cn color printer and on the display screen it says 094-910 Insert Belt Unit... can you please tell me what I need to do because at this point we are not able to print anything? THanks,
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
SOURCE: Dark prints when printing from my Imac using Leopard
What worked for me was to pre-set the Epson Stylus Photo (in my case SP R1800) as the DEFAULT PRINTER before (very important BEFORE) launching Photoshop.
Following is a quick summary of key steps. It is assumed that you are familiar with a CS3 workflow. It is not a step-by-step guide for users new to this. All this is really adding is the tip I read in another forum (thanks to whomever it was) to set your photo printer as the default before launching Photoshop.
Before I did this, I had all sorts of problems that I had to fix with letting the Printer Manage, and making Levels or Brightness compensations in Adjustment Layers.
MacBook Pro (early 08, 2.6GHz, 4GB; Leopard; Cinema Display (calibrated and as dark as possible); CS3. Epson Ultra Premium Luster, and Epson Double-sided Matte.
Workflow: Calibrate the display; Install and update all the Epson Drivers; Select SP as Default Printer in Print and Fax System Prefs; Convert or assign Adobe RGB as Working Space and Image Profile; Choose SP in Page setup and the right paper size. In Color Settings Dialog under CS3 File Menu, choose North American PrePress; in the Print Dialog in CS3, Allow Photoshop to manage color (popup), and choose the Printer+Paper profile combo under the popup.
Then when you do Print, make sure all your paper settings are correct and Color management is set to off.
Now I can also nail prints out of Pages and Preview (but need to set color management to ColorSync in the Print Dialog).
No guarantee this will work for you. But it did for me, providing I was doing EVERYTHING ELSE by the book. You may want to cut up larger sheets of expensive paper to use as test prints first. Just make sure they will pass through the printer (don't cut too small, and make sure they are rectilinear). Choose a standard paper size that is slightly smaller than what you have cut. The check "scale to fit media. Should work
Posted on Jan 27, 2009
yooperbud
  • 8637 Answers
SOURCE: Black ink cartridge is 2/3 full, but doesn't print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
1alexh
  • 484 Answers
SOURCE: my Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
Posted on May 22, 2009
SOURCE: my hp printer f4280 display E on the start/copy
my printer after i refill still shows empty and not printing.please give me the solution i cannot afford to always buy a new cartridge.thank you
Posted on Oct 05, 2009
Error code 093-921
If you are seeing any or all of these error codes on the Dell 3130cn Laser Pinter that there is a Firmware Update to address this issue. However, the firmware cannot be applied when there is an error present, so first try reseating all toners. You may need to repeat this several times before errors are cleared. Once error-free, download the Firmware from the Dell Support website and apply.
Reset the Cyan toner properly.
Follow
TapeOn a cart... Cart Error 093-919, 093-920, 093-921, 093-922 on a Dell Color Laser Printer 3110cn 3115cn 3130cn tape POST Laser Printer 3110cn 3115cn 3130cn
  1. Verify all packaging has been removed from the printer cartridge. This includes any tape or red handles. Also verify the toner cartridge is properly installed.
  2. Remove the toner cartridge and clean the toner housing of any excess toner with a clean dry cloth. Reseat the toner cartridge when finished cleaning.
  3. Check that all toners are Dell branded and not refills. Take note of all PPIDs (Serial Numbers). Check that all toners are for the correct model
    • If any toners are non Dell, swap with another toner
  4. Run diagnostics on the toner cartridge sensor.
    1. Power off the printer.
    2. Hold down the and buttons on the printer and power the printer on.
    3. Release your fingers from the keys when the message Diagnosing... appears.
      Customer Mode and ESS Diag display.
    4. Press the button until IOT Diag appears and press the button.
      On the LCD, Digital Input appears.
    5. Press the button until Digital Input appears and press the button.
    6. Press the or button until DI-8 for (yellow) DI-9 for (Magenta) DI-b for (Cyan) and DI-a for (Black) appears and press the button twice. It is only necessary to run the diagnostic on the toner cartridge to which the error applies
    7. Open the front cover. (Figure 1)
      Figure 1 - Open the Front Cover
    8. Remove and replace the toner cartridge. Every time the toner cartridge is reseated, the counter on the Operator Panel will increase by 1.
      • If the diagnostic does not increase by 1 then replace the toner cartridge.
      • If the diagnostic does increase by 1 and the error persists, Please contact Dell Technical Support for further advice.
Knowledge Base
Mar 02, 2016 | Dell 3130cn Color Laser Printer
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
How to reset dell 3130cn to factory defaults
Go here: http://en.community.dell.com/support-forums/peripherals/f/3528/t/19494398.aspx
Jul 09, 2014 | Dell 3130cn Color Laser Printer
3130cn not a clean print
This is a bit vague for a description of a problem.
Details.
How is it not clean?
Is it an overall colour background?
Is it producing 'smudgy' prints (that rub off the page)?
The pagecount of the printer could be useful - indicates how much use the printer has had 0 could point to wear somewhere.
Have you replaced any of the toner cartridges, fuser, of transfer belt recently.
Are you using different paper (than when you were getting good print)?
Oct 02, 2013 | Dell 3130cn Color Laser Printer
Just bought Dell printer 3130cn, and am trying to install it on a network. Unfortunately the printer says "error 006-370 restart printer". I have tried restarting multiple times in different ways...
This error relates to condensation that was detected in your printer. You should not use the printer for more than one hour.
If this does not solve the problem, you should contact Dell at 1-877-293-119.
Apr 19, 2011 | Dell 3130cn Color Laser Printer
I ran out of toner, so i refilled the toner and put it back into the printer, it is still reading empty and will not print unless i put in a new cartridge. please help
Today printers have a chip in the toner that indicates if the cartridge is empty or full. Even if you fill the cartridge, it doesn't matter. The chip is telling the printer "it is empty", so as you can see, Dell wants your money.
Sorry about that.
Dec 11, 2010 | Dell 3130cn Color Laser Printer
Displaying 077-901 paper jam. How do I repair?
Please perform the steps mentioned in the link below:
Paper Jam
Let me know if this worked.
Jun 17, 2010 | Dell 3130cn Color Laser Printer
286 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
