Question about Panasonic Televison & Video
My 3 month old Panasonic Plasma TV (TH-42PZ700A) has suddenly lost its accurate colour control (particularly noticeable on skin tones). Prior to this happening the skin tones were perfect. It followed the TV's switching off by its self for some reason. This has happened before but the next day the colour control returned to perfect - not this time. My control setings remain unchanged.
  • Anonymous Mar 12, 2014
    all other controls perfect can see no reason why this one should suddenly stop working
    President:
  • 624 Answers
Since this is only 3 months old it is still under manufacturs warranty. Anyhting you may do to the TV may void it's warranty. I work at an authorized service center and have seen too many times when people think they can fix something themselves and end up with a voided warranty. You really should take it in or have a authorized service center come to your home and check it out for you. In home service is offered by manufacturers and is normally covered by the warranty.
Anything you may be able to do to get it working this time will most likely happen again since it has happened before. Getting it serviced by an authorized service center may fix the problem permanently.
This may not be the answer you are looking for, but it is the smartest thing you can do. A little hassle now getting it fixed properly will propably save you money and more of a hassle in the future.
Posted on Aug 06, 2008
  • 2,071 Answers
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Picture quality deteriorated
Most like one of the scan drive boards is failing. It would need troubleshooting to determine which board is weak.
Apr 17, 2014 | Panasonic Viera TH-50PZ85U Plasma TV
Panasonic TH-42PD50Uscreen colors all appear pink and green
the colour sensor on the picture display may have lost functioning....as in case of plasma tv`s the they use transistors for colour ......so better call a technician from the related company and do a check up.....no other solutions i hope.....
Jan 02, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Thick lines descending plasma screen
maybe you have interference with other electrical component near your tv. move the component, example cable box, dvd, sat box.
Apr 14, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-37PX600B TV pixelation
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Apr 12, 2017 | Panasonic TH37PX60 37 in. Plasma...
How do I connect my Wii to my Panasonic plasma tv?
the wii leads are colour coded look for the colours on tv then switch tv into that input mode e.g ( common or EXT ) make sure wii is on
Nov 29, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Red led flashes. when i try to turn tv on it shuts off immediately. it's a panasonic th-42pz700a
There should be a number of flashes that you can count. This is an error code. It will flash a number of times and stop. Again, Flash a number of times and stop. Contact a repair shop that is familiar with panasonic and have them to check it out.
Oct 14, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Plasma TV
Try to reset the TV to factory defaults and see if that helps. Record your color settings and any other setting your have in your config before dong this because all will be lost.
Jul 14, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
