Question about Sony Audio Players & Recorders
I have a STR-DA3ES receiver and it is showing "protector please power off" in the display. I have powered off and disconnected each speaker, one at a time, and it still occurs.
  • jhaverty8 Apr 05, 2011
    Thanks for your help. I'll get the vacuum out before I take it in for repair.
    Brigadier General:
  • 8,546 Answers
Disconnect all the speakers at once just to be sure the problem is internal.
Is it overheating?
Posted on Apr 05, 2011
    I disconnected all speakers and the "protector" message came on within three minutes. The unit does not seem to be overheating
  • David Dunn
    David Dunn Apr 05, 2011
    If it took three minutes I'm betting heat is an issue at some component level if not overall. You could search in vain for the exact cause and replace a given suspicious component or you could let a hands-on guy troubleshoot it and hold him responsible for as result.
    Make sure there are o clogged ventilation holes or dust bunnies living inside it.
DA 3ES powers on, shows the appropriate connections i.e. opt for directv playstation, etc , but has no sound for any sources. Several of the orange lights remain lit, audio split, and others and the...
Great testimony for those Monster surge protectors, huh?
Did the failure coincide with the storms? If so, stick a fork in it, it's done.
Just the same, if you really want an assessment as to damage and cost you need to have someone knowledgeable give it the sniff test in person.
No one out here can do that.
Mar 13, 2011 | Sony STR-DA3ES Receiver
My SONY STR-DE835 receiver amplifier is showing PROTECTOR on the digital readout.Anybody know what that means.
These models are known for this issue.
I've had my share in the shop here.
Disconnect all speakers,turn speakers off, try headphones only
If it still persists then there is either :
1. power supply capacitors gone bad or 2. The thermal fuse in the transformer is open.
A tech can very easily find out if the thermal fuse is open by checking the primary of the transformer
if the plastic is shrinking away from the power supply capacitors then they've gone bad
Jul 27, 2010 | Sony STR-DE835 Receiver
Message "PROTECTOR"
Disconnect all speakers at the receiver and power it back on. If it stays on, check all speaker wires and speakers for shorts. If it cuts out, it needs service. If you need detailed troubleshooting help on this after testing receiver without speakers connected and it passes, post a comment and I can walk you thru it. Hope this helps.
Oct 24, 2009 | Sony STR-DE625
PROTECTOR/CHECK CODE 21 COMES ON ONCE A WEEK OR SO.
STR-DA2000ES, STR-DA3000ES and STR-DA5000ES:
Doument Reference: E23914196
Subject/Description: "Protect 21" is displayed when connecting to speaker/powered subwoofer combo
SYMPTOMS
Protect 21 is displayed when connecting to speaker/powered subwoofer combination model such as the SA-VA7000ED. The problem was also found to occur when connected to the Definitive Technology POWER MONITOR 500 and POWER MONITOR 700 series speakers.
CAUSE
The DC detection circuit is triggered when the speakers are connected.
RESOLUTION
Add a 4.7k metal oxide film resistor across capacitors C1319 and C1329 located on the D-AMP board.
Hope this helps. =)
Oct 23, 2009 | Sony STR-DA5000ES Receiver
MySony str-da5000es is showing error code 11 and shut off by itself after few seconds.check and disconnect all speakers, unplugged power from wall and still showing error 11. am missing something in here...
error code 11 (protector) - According to the manual, 11/PROTECTOR means, "Irregular current is output from the speakers. Turn of the receiver, check the speaker connection and turn on the power again." Most likely, a strand of speaker wire is shorted to the chassis at one of the speaker terminals.
Hope this helps !
Jun 17, 2009 | Sony STR-DA5000ES Receiver
Error code - protector
Try disconnecting all the speakers from the back and turn the unit back on. If the "protector" display goes away, turn the unit back off and reconnect one speaker. Turn it back on and check for "protector". Repeat.
If you find that one of the speakers causes "protector" to appear, you either have a bad speaker cable or bad speaker. Try swapping each of those out to see what happens.
Apr 20, 2009 | Sony STR-DA90ESG
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Noise and popping on Sony STR-DA3ES
Sounds like its going to square wave clipping and poking a dc offset at your speakers. Happens when the amp reaches power supply ceilings. Pink noise such as "rain sound" will push the output stages and power supply to limits. If its on all channels, check power supply caps and check for dry solder joints. also look for that crappy brown hold down glue that goes conductive/corrosive. check all output stages particularly about discrete output devices that are attached to heat-sinks. They have a bad habit of dry jointing also. Good Luck
looked for a free manual on line for you
http://www.nodevice.com/manual/Sony/page139.html got heaps... but not your exact model. You may be able to cross reference one
Feb 03, 2008 | Sony STR-DA3ES Receiver
Protector is flashing with the words under it saying"please power off" about 5 secs after I turn on my receiver
this happened to me.  one of the speaker wires had become unplugged and was touching another one... causing a short.  glad to know this unit is "smart" enought not to fry itself.
Oct 01, 2007 | Sony STR-DA3ES Receiver
155 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
