Question about Compaq Computers & Internet
Charging Light is on when battery in , and charger plugged in , no reaction when power switch is pressed , fan not spinning ,no power light ,nothing . When battery take out , no charging light when charger plugged in . can anyone gv me some opinion ? Thanks!!
    Novelist:
  • 151 Answers
This sounds like a USB problem. If there is a short or damage within the port the computor will detect it and prevent it from starting. Usually it's a USB port you always use. This may help, Plug in the mains charger and remove all USB devices. This will confirm weather its the computer or a USB cable/device. If the computer still doesn't start, get a bright light and a magnifying glass and look inside all the USB ports on the computer. In the middle of the port there is a flat plastic piece with 4 metal contacts attached to it. Check to see if they are bent, twisted or flattened in any way and with a pin or other suitable pointy device, attempt to straighten any damaged contacts. If you cannot get the contacts aligned, just try to get them away from each other and away from the wall of the port, then insert a piece of card or folded paper above and below the contact strip and tape them down. This will insulate the port and stop a reoccurance of the problem. You should find the computer starts (with a few complaints from windows) normally. this has worked for me 9 times out of 10 for this problem.
Good luck.
Posted on Apr 05, 2011
Hi I have a samsung notebook. When I plug in the charger the light comes on to indicate it is charging. But when I press the button to turn it on nothing happens. I have tried turning it on with the...
hopefully maybe the charger is bad ..the light might be on only indicating power coming into the adapter but not out!!!..invest in a new charger and battery
Apr 14, 2013 | Computers & Internet
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
I cant turn on my HP520 notebook pc. when i press the power button, it blinks once, and the charging light blinks for 9times(orange light, the 8th times was green light) i tried to remove the battery and...
Alright, not sure if this will help, by my understanding is that you are saying that when you power the computer using the power supply adapter, nothing comes on? Then when you have your battery installed on, then there are lights blinking from your battery charger LED amount of times. In this case there are no promblem with your laptop and it is your power supply adapter that is damaged and will need to be replaced. It is not charging the battery. The battery is still good, but does not have enought charge to power up your system. You can find a charger on ebay for a good reasonable price compare to getting it from Hp. I hope this can help you.
Jan 13, 2011 | Computers & Internet
Spilled a glass of red wine across the table, a little got on my wife's closed laptop, under it and a little on the inside I'm sure. Power cord works, lights up, recognizes the charger and says charging....
Place your laptop in the sun light for 3 or 4 hour ,and again start the laptop .Also you will remove the battery and the dc adapter .press the on of switch for 30 seconds.AGAIN INSTALL THE BATTERY AND THE ADAPTER .I THINK IT SOLVE YOUR PROBLEM.
Dec 16, 2010 | Computers & Internet
Laptop only turns on every now and then, charger pluged in but charger light not on, when trying to turn on fan kicks in, charger light flashes, then nothing, please help?
It sounds like you have a bad charger cord. Does it do the same when powered off the battery? Like it is tryin to start up. An d also make sure battery is plugged in good to the laptop,
Oct 31, 2010 | HP Compaq nx5000 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Power light comes on and goes off and machine is dead
The Motherboard is bad but before you buy one.Try this Remove the memory, cd rom,hard drive battery, power adapter. Press and hold the power button down for about twenty .Replace the memory only,power up if you get the same result the motherboard has to be replace
Sep 15, 2009 | Dell Inspiron 9300 Notebook
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Jul 02, 2009 | HP Compaq Presario F500 F700 and G6000...
Lenovo z51t, no indication of life when power up
Try this. Turn off unit. Unplug charger. Take out battery. Replug charger - not battery. Turn on computer. If it comes on the battery has a glitch and should recover after an hour or so. If it doesn't come on, the unit needs to see a reputable computer repairperson.
Good Luck
Mar 21, 2009 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
