Question about KitchenAid KSCS25IN Side by Side Refrigerator
Ice dispenser spring in door
The spring for the ice lever in the door has come out. How do I remover the cover on the ice/water dispenser to reach the lever?
There should be two slots in the bottom of the panel. Use a screwfriver to pop this out. You will have to unscrew the electrical panel to expose the dispenser area. Be wure to unplug the unit first and be careful not to break any wires.
Posted on Sep 23, 2008
How do you remove the in the door dispenser cup and lever for cleaning
Depends on the make/model, but usually there are a few screws that go in from the front that hold the plastic arms in place along with the spring blade. Most of the time you need to remove the decorative plastic cover around the front of the dispenser to get at them. Pay attention to how things go together, or take pics before and during the process. It will save you a lot of headaches later.
Mar 20, 2015 | Refrigerators
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
How do you remove the face plate off of the ice/water controls on the outside of the freezer door? The spring came off the flapper door that covers up the ice delivery hole, nothing has broke, but I need...
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Door faceplate removal
open the door pull the door seal, you should see some screws that hold the seal in place you wil have to remove all of them around the door,this will free the inside liner and you will have complete acces to the water and ice dispansers from the backdoor
Mar 08, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker stopped working, still get water to dispenser. fan works, don't know whatelse to check?
If your freezer is working, and water is reaching the ice fins/tray; check that the metal wire lever is in the down position for dispensing water and/or up for when ice is ready. The lever activates a small valve that allows water to drip onto the ice fins/tray...
Jan 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Mold/Bacteria formed between ice dispenser and dispenser lever Can dispenser be removed from lever for cleaning? If not, how to clean?
Use a bathroom mold and bacteria remover spray available from most supermarkets. Also spray down into the feeder on the inside of the door. Make sure you rinse the area thoroughly after use and run water through the water chiller dispenser and run some ice throughthe ice dispenser and throw these away. Then it should be safe to use.
Sep 30, 2009 | Kenmore Refrigerators
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Replace dispenser arm
on the bottom of the ice dispenser front cover is 2 slots insert a small screw driver into these slots and carefully pry the cover off (be careful not to scratch your door) one the cover is off there will most likely be a wiring harness that you can unplug and put cover out of your way. next you will need to move the white bracket out of your way there is either 2 thumb latches or 2 screws that seure it. it will not come all the way out so you may need someone to hold it out of the way for you. in the center of both of your levers you will see 1 screw with a cardboard spacer and brass spring BE CAREFUL NOT TO LOOSE THESE! remover screw spacer and spring afte that you should be able to work the levers right on out. the ice lever is a little tricky trying to get it around the ice door but it will come out.
Jan 31, 2009 | Refrigerators
Replacing refrigerator door arm
on the bottom of the ice dispenser front cover is 2 slots insert a small screw driver into these slots and carefully pry the cover off (be careful not to scratch your door) one the cover is off there will most likely be a wiring harness that you can unplug and put cover out of your way. next you will need to move the white bracket out of your way there is either 2 thumb latches or 2 screws that seure it. it will not come all the way out so you may need someone to hold it out of the way for you. in the center of both of your levers you will see 1 screw with a cardboard spacer and brass spring BE CAREFUL NOT TO LOOSE THESE! remover screw spacer and spring afte that you should be able to work the levers right on out. the ice lever is a little tricky trying to get it around the ice door but it will come out. btw just use white vinegar to clean hard water stains in the future. thx peyton... also dont forget to unplug the refrig.
Jan 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
KitchenAid KSCS25IN Side by Side Refrigerator Logo
209 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
