Question about Canon PIXMA iP90 Mobile Printer
Priter Jams When the paper in my IP90 first enters it gets kicked off to the side and wrinkles as it goes through the printer
  • 928 Answers
Sometimes this happens when the paper is too thin. Have you tried ordinary substance 20 paper? Also see if the guide for the paper is set correctly according to the size of the paper that you are using. this especially happens if the guide is not able to correctly set the paper straight before it is fed
Posted on Aug 06, 2008
  • Thomas Lim
    Thomas Lim Aug 06, 2008
    Check if the feed rollers are clean and if the guide is aligned
  • Canon Master
  • 6,487 Answers
Follow this:
Isolate the jam by determining where it is occurring. This sounds much easier than it looks because a jam can be caused by more than one thing, and some jams do not occur frequently enough to be isolated. Solid failures are easier to isolate. Is it happening as the paper goes in, while it's coming out, or somewhere in between? Turn off the printer's power if the jam is far inside the printer. You can tell how far along the jam is by how much of the paper has already emerged onto the paper output tray. If you see only an inch of paper poking out--or none at all--chances are there's some ugly stuff going on in the inside of the printer. You don't know until you look inside whether a part was merely out of place, constituting an isolated incident or whether internal wear and tear has been building up for a long time, which means you have a festering problem on your hands.
Once the jammed paper is discovered, grasp it firmly with both hands and pull straight so the paper doesn't tear. It is very important to use both hands, leveraging your strength on both sides of the paper because you could create more problems if it tears inside the printer.
If the paper happens to rip, rotate the gears by hand to back the remainder of the paper out of the printer.
Hope that helps......
Paper Jams
The printer should be on,remove the paper from the printer(if there is any),press and hold the down arrow/cancel button, release the button when the power light blinks 3 times ... The printer will rollers will automatically revolce and clear all the jams.. When the power light is green then repeat the same step 3-4 times.. To confirm the paper jam is cleared then feed 8 1/2 * 11 paper in the printer and again press the down arrow button and release the button once the power light bliks for 3 times and then release the button. If the printer feeds properly it confirms the hardware of the printer is fine.
Software issue: Go to printer and faxes in computer and check the icon. If it says.. 0 paper jam then, delete the icon and chcek in the device manager if there is an entry of usb printing support under Universal Serial Bus controller .. if the entry is there then delete it. Insert the printer cd in the computer and unplug and replug the usb cable from the printer. If the setup screen comes up then exit out of it and the printer drivers will get updated. After that tried to print another tets page from the computer. It will definately print.
Aug 06, 2008 | Canon PIXMA iP90 Mobile Printer
Canon Pixma 5000 - paper feeds such that one side goes in faster
Your rollers are not up at that side, try manually raise them up to see if that helped.
Nov 24, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Paper jam in Canon PIXMA iP90
one of your feed gears has poped out of placeor one of the teeth is broken,check the paper path with a flashlight you will probably see one loose.
Good luck
Aug 28, 2009 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA MP480 bought 4 months ago jams paper
paper jam problems are usually occured by dust and debris in the printer . clean up ur printer from inside . also align ur paper tray. that will fix the problem. thanks and take care of urself.
Jun 09, 2009 | Canon Pixma MP480 All-In-One InkJet...
Need help re aligning where paper goes
HI,
can you open the cover of your printer and look again inside.
remember even a small tiny paper will caused this problem so if your rpinter is still having this problem then double check the printer inside.
thanks
May 23, 2009 | Canon PIXMA iP90 Mobile Printer
Wrinkled jammed paper
paper weight to light change it.
Sep 11, 2008 | Brother HL-2040 Laser Printer
Install Bluetooth unit
There is a place at the front left as you open the cartridge door that the BlueTooth adapter fits in. It goes in with the circuit side going into the hole in the priter housing.
Jan 05, 2008 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
56 people viewed this question
old marine
old marine
