Question about Panasonic Microwave Ovens
The panasonic micro/convection oven (NN C 867 BV) in my 2000 Rv does not turn on at all. I removed it and tried it on a house outlet still no dice. After removing it there was a baggie with 2 fuses (18 amp). I have not unscrewed the back yet, just wondering about the shock thing. Is it obvious what I should not touch? What if the fuse is not the problem?
SOURCE: Panasonic NN 9850 wall micro/convection oven
PLEASE CHANGE MEMBRANE SWITCH
Posted on Oct 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Dimension 4 microwave model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Posted on Aug 03, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 18, 2008
WhIzAtIt
  • 136 Answers
SOURCE: Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Posted on Sep 24, 2008
SOURCE: Microwave stopped working while cooking. Is there a fuse?
If unit is built-in reove screws holding unit to cabinet.
Slide out about 2 inches to access 3 screws holding grill.
Remove grill to get to two screws holding control panel.
Fuse is behind control panel,
Posted on Mar 17, 2009
Panasonic convection oven nn-cd989s, complete power off during prebake cycle of 450 deg which was directed to remove light oil coating from manufacturing process . Now unit has no power on face panel
Check the 20 amp fuse where the power cord ends inside the oven. If it is open check the latch switches. If the switches check ok the invertor is probably bad, smoking.
Dec 20, 2014 | Panasonic Genius Prestige NN-CD989S -...
No mater time salected only cooks for 17 seconds
i think you have a problem with your magnetron or the inverterpcb if your unit has inverter inside writen on the front it could be an expensive repair please contact me to let me know iffell up to tackling this repair as it can be dangerous
Dec 09, 2012 | Panasonic NN-T888S Convection/Microwave...
I have a Panasonci NN-SD686S and after a power cut last night, the microwave is now in demo mode. After power cuts previously this has never happened, and I can't find anything in my manual to...
To set Demonstration Mode: press micro power once, then press Stop/Cancel 4 times. To cancel Demonstration Mode press Micro power once, then press Stop/Cancel 4 times.
Sep 09, 2011 | Panasonic NN-C994S Convection/Microwave...
When started,light& turntable operate normally,but no heating by microwave. Transformer normally sounds smooth,but now makes rattle or vibrating noise,like something is loose.
Check the door safety intertlock micro switch for proper behavior. If it is faulty, the oven will think the door is open and will not turn on the magnatron.
Sep 22, 2010 | Panasonic NN-C980 Convection/Microwave...
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
My panasonic microwave [genius] has no power,after a power outage
Remove the cover (5 screws on rear and pull away from front) and replace the fuse at right side rear. (15amp 125v)
May 14, 2009 | Panasonic NN-T888S Convection/Microwave...
Our NN-8500/NN-8501V Micro/Convection is no longer repairable
hi Peggi and john, have a look here for repairs and new in Dallas TX area:
http://www.superpages.com/bp/Dallas-TX/Affordable-Appliance-Repair-L2069127442.htm?SRC=portals&C=Range+%26+Oven+Sales+%26+Service&lbp=1
regards from the UK :)
Nov 21, 2008 | Panasonic NN-T888S Convection/Microwave...
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
42 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
