Question about Ricoh Aficio 1018D Copier
Photocopy ricoh aficio 1018 - Ricoh Aficio 1018D Copier
  • santosj27
    santosj27 Apr 05, 2011
    Yes! Congratulations! You have a Ricoh!
    LOL... And what is realy your problem???????
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
What is your prolem
Posted on Apr 06, 2011
  • 1 more comment
  • santosj27
    santosj27 Apr 20, 2011
    Once again... dont post.
    If you nead you have a clarification option.
    Do you know what that mean?
    See you good technition
  • plagio omar Apr 20, 2011
    **** yo if yo haven't knowledge yo must be silence not talking tooooooooo much
  • santosj27
    Yes yes... i know that you are a GOOD technition and also i know that you know every model and every problem.
    So... why so few helped people???? Can you answer me that?
What cause faint copy on the photocopy machine?
SHORTAGE OF DEVELOPER, DIRTY LASER GLASS,WEAK DEVELOPER AND WEAK OPC, DRUM NIT NOT SET CORRECTLY IN POSITION.
Oct 31, 2012 | Ricoh Aficio 1018 Printer
What's the cause of faint print on a photocopying machine?
The toner could be low. That is the first thing I would check.
Sep 24, 2012 | Ricoh Aficio 1018 Printer
We have Ricoh Aficio 1018 , machine functions , gives print without the matter printed
Sounds like a bad photoconductor unit (PCU), or problem with the transfer roller which is mouned inside the right side door. The PCU consists of 2 main sections; the development unit, with developer ang mag roll (on the bottom) and drum, with charge roller and cleaning blade (on the top). If the gears that turn the mag roll go bad, toner will not be applied to the charged drum. If the transfer roller is missing or not being charged the image will not be transferred to the paper. Check the connector from the copier to the right side door and the leaf springs that carry the charge from that wire and contact the transfer roller.
Sep 07, 2012 | Ricoh Aficio 1018 Printer
Functional problem sc 390 on ricoh photocopier, despite replacing drum, developer,blade,gears. after removing 9 copies it reads functional problem.
SC 390 on an Aficio 1018 will most likely be a bad TD (toner density) sensor, if you've already replaced the drum and developer. (One thing to check quickly though is to pull the PCU out and reinstall it, just to make sure that connection isn't the problem.)
You can either replace the TD sensor by itself, or replace the DV unit (which probably won't be much more expensive). But either way, you'll need to install new developer when you replace the parts.
Aug 17, 2011 | Ricoh Aficio 1018 Printer
Large broad grey lines on all photocopies
Hello sir; The problem you have , you do need a drum cleaning blade to replace and also image transfer roller need to clean with alcohal.
May 26, 2009 | Ricoh Aficio 1013F Copier
Ricoh aficio 1018 printer
yes you have to install the drivers and give the usb option for communication
Aug 05, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Nov 30, 2007 | Office Equipment & Supplies
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
