No heat is coming out. Air is being taken in, and I can hear it running, but it is not blowing heat out.
    Brigadier General:
  • 3,917 Answers
Hi
It's mainly the problem with the thermostat, please check this links bellow for the no heat problem:-
http://homerepair.about.com/od/heatingcoolingrepair/ss/gas_furn_trblsh_2.htm
http://www.inspectapedia.com/heat/NoFurnaceHeat.htm
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 05, 2011
Problem with heating up and staying heated.
Thermostat is sticking or heater core is blocked.do not keep running it or it is going to ruin the engine. It is running hot regardless if is blowing cool or hot air. Do not keep using the car.
Apr 16, 2017 | 1997 Oldsmobile Bravada
Problem heating up and staying heated.
the heater has went out of it or something is keeping it from trying to get it to warm up
Feb 08, 2014 | 1997 Oldsmobile Bravada
Fan blows air, but no heat or ac
May be your air modulator. Do you hear a clicking sound behind the dashboard?
Jan 04, 2014 | 2000 Lexus ES 300
You can hear the heat trying to kick on but only blows cold air. If I slap the side of the unit - the heat comes on and heats the room to the temperature on the thermostat and shuts off. When the unit...
Sounds like you have a heat pump with either a stuck reversing valve or a loose wire going to the reversing valve solenoid. Open it up and take a look. Keep slapping it and you'll break something!
Dec 03, 2013 | Amana PTC153B50AM Split System Air...
I can hear the air compressor come on but doesn't blow cold
If it is blowing air and the compressor is running you are low on freon more than likely. make sure the fan on the unit is also running it helps it get rid of heat on the external coils. if all fans are running and the compressor is running it is low on freon.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
AC/heat doesn't come out front vents. Can hear
try a vaccum leak under the hood. Look and listen for any little sounds of air blowing out. Also the door switch may not be turning to vent it may be stuck on one side, like defrost!
Nov 23, 2009 | 2001 Oldsmobile Silhouette
1992 GMC suburban front air don't blow
REMOVE THE BLOWER MOTOR CHECK IT.HOOK IT TO BATTERY TO SEE HOW WELL IT WORKS. IF IT RUN SLOW OR RUN STOP RUN.REPLACE IT.IF IT CHECKS OUT OKAY.THE PROBLEM. COULD BE THE AC+ HEAT- CONTROL MODE SWITCH.
Aug 02, 2009 | 1992 GMC Suburban
Gas Furnace is not heating anymore.
the fan you hear come on at a call for heat is most likely just the inducer motor. the click you hear is probably the relay for the hot surface ignitor which should glow red, then in turn ignite the main burners. your going to have to determine if the ignitor is coming on. if it isnt the ignitor is bad and will need to be replaced. if it comes on and than shuts off after a few seconds the ifc board is probably at fault
Apr 09, 2009 | Heating & Cooling
2006 Ford explorer/No heat /overheating
Sounds like you are either low on coolant, or a head gasket failure.
Nov 18, 2008 | 2006 Ford Explorer Sport Trac
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
