Capacitors??? WOMAN NEEDS HELP PLEASE!!!???
I have a Proview monitor Product # PL913s Model 900P. It has no power. When I opened it up, there are burn marks near two of the capacitors. One was, I believe, 47ouf 25v and the other is 25v 150ouf. I am looking thru the catalog like you suggested for a 105c but what capacitor should I get? The same as it had or something stronger? What parts numbers do you suggest? Cause I certainly wouldnt want to get the wrong thing and blow it up or something serioulsy happen to it.
Your help is greatly appreciated.
Anekali@aol.com
Thanks for your help in advance,
Annette
>>>>You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
  • Anonymous Jan 17, 2009
    I have the same Proview Pl913s 900w 19" monitor and the screen was white when I came home from work, from there I turned it off for about a hour to two and tryed to turn it on again and it powered on and then off, So I read the posts on here and changed 5 of the 6 caps and now it powers up but screen is white, tried to let it warm up but it shut off after 10 mins any suggestions
  • 3 Answers
The term: "it has no power" is not specific enough. If the actual led indicator light on the front of the monitor lights up with a green color, then goes out or starts flashing, then maybe, perhaps the problem with the monitor is that the high voltage power supply for the screen backlights is not working. The common components that fail are the capacitors on the high voltage power supply board. If the capacitors are swollen or leaking, they are probably bad. You must replace a capacitor with the exact size of capacitance. You cannot replace with a "stronger" capacitor. You can replace with a higher temperature rated capacitor, if the capacitor will fit in the alloted space on the circuit board and in the case.
Posted on Aug 06, 2008
Product NO. PL916s Model NO. 900P I have a Proview monitor, which has always worked wonderfully. Recently my computer broke down and I'm using another computer with a small screen. I have misplaced...
Product NO. PL916s Model NO? This trouble maybe power supply or inverter boards is defective. first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
AI 0088 Proview 860 ALZ M713W Power Supply for PL916S
Jul 21, 2011 | Proview PL916S2 Monitor
My Proview monitor PL916s model# 900P built in 2004 suddenly shut off and will not turn back on. There were no previous problems with it and this is the 2nd monitor (same brand and model) which has done...
My Proview monitor PL916s model? This trouble maybe power supply or inverter boards is defective.
Apr 12, 2011 | Proview PL916S2 Monitor
Hello, i need the inverter for this monitor proview pl913s silver 19 inc. flat panel lcd. product# pl913s The monitor turns on and shots off after a second. how can i resolve this thanks
Did you inspect the caps for domed tops in the power supply/inverter board yet? Worst case will be the lamps assembly.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 14, 2011 | Proview PL913S 19" Flat Panel LCD Monitor
I have Monitor Proview PL916S 900P It turns on
spc12b, Have you tried the flashlight test yet? How old is this monitor? Your monitor has a 2 types of power supplys in it. A switch-mode-power-supply and an "INVERTER" supply. One or both of them could be having a problem. The inverter needs DC from the smps to change it into AC to light up the cold-cathode-fluorescent-tubes that are hung in back of the lcd panel. Let me know results of flashlight test. After screen goes black, hold light 1-2" from screen at different angles. Let me know if you still can see the win-desktop screen even though it is still dark.. Bye for now. louie12fix on fixya or lmistyrel @aol.com
Aug 12, 2009 | Proview PL916S2 Monitor
Proview monitor blacking out
i would suggest getting a new monitor you might have made it overheat or your display driver failed.
Feb 16, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Moniter clicking
check capacitors inside for damage is found replace them
Feb 13, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Flat screen monitor
I would open the monitor and look for bad capacitors on the power board
May 27, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Monitor works on one computer, but not the other
The problem is not your monitor, but the video card on your computer that it doesn't work on. If the video output on your computer is built in, residing near your keyboard / mouse ports, you can purchase another video card to put into your computer and connect your monitor up to that instead. If it attaches to a separate card inside your computer, just replace it. There are three kinds you can get, AGP, PCI, or PCIe. Make sure you get one that will fit inside your computer.
Jun 26, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Computers & Internet Logo
1,321 people viewed this question
David Payne
David Payne
