Question about Samsung BDC6900 3D Bluray Disc Player
My Samsung BD-C6900 will not play any discs. The player tries to load them over an extended period, (90 seconds) but the error message appears "Cannot play this disc". The Blu-Ray and DVD Discs are brand new. I have applied the latest 1019.0 Software Upgrade, but still the Disc Player Does not work. Any ideas?
  • Samsung Master
  • 2,098 Answers
Hi dcarroll547,
You may find friends that can perform the steps below...
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 05, 2011
Samsung bd 6900 stopped playing blue ray or 3d movies
check if the firmware is updated,if those bluray disc are previously working on that machine if thats the case then the unit needs to be repair, the lens of the bluray might be faulty
May 05, 2014 | Samsung BD-C6900 Blu-ray 3D Player
Samsung bd-c6900 xaa dvd player freezes on 3d prometheus movie in same spot at scene 20
Report the error to Samsung support. There is an ongoing problem with the firmware. Make sure you have updated to the most recent firmware version 1025.0 that was released this month. There are still unresolved problems with the new firmware release though. Many movies will fail to load and other will load and play but will skip/freeze during playback. This is related to the anti-piracy features on the Blu-Ray that the player can not properly handle.
Mar 30, 2013 | Samsung BD-C6900 Blu-ray 3D Player
Bluray BD-6900 turns and is stuck on Load. No menu, nothing on screen, just the word LOAD displayed
Hello
Its laser pickup unit should be suspected. Just insert a lens cleaning disc and try to clean it. If it do not help you, the set need service
Mar 04, 2012 | Samsung BD-C6900 Blu-ray 3D Player
This disk does not fit the specifications
With a Samsung playe you go into your settings and for your BD Live feature you 'PROHIBIT" it and the disc will work fine. Here are the steps.
1) Settings
2)Network
3)BD-LIVE Interernet Connection
4)Select PROHIBIT
5)EXIT
it is good to go back ito menu to make sure it saved it.
Feb 12, 2012 | Samsung BD-C6900 Blu-ray 3D Player
I bought a Samsung BD C6900 from USA designed for region 1 and A . Living in Europe I cannot play my european DVDs and BDs ? Are there any solutions to change the region code ?
Here is a solution: http://www.videohelp.com/dvdhacks/samsung-bd-c6900/10895
Please note, however, that even after region code hack, it may remain NTSC only, so if you are planning to play European DVDs recorded with PAL system, it may not work.
Feb 27, 2011 | Samsung BD-C6900 Blu-ray 3D Player
Samsung BDC6900 3D Bluray Disc Player Logo
403 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
