Question about Sony RCD-W500C 5-Disc CD Recorder
It records fine, but then when trying to copy the recorded cd, it stops in between
    Brigadier General:
  • 8,546 Answers
It won't make digital copies of digital copies. Read about SCMS in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-RCD-W500C-manual/id/423ag417/t/2/
Set Post Gap to OFF (Page 34)
Posted on Apr 05, 2011
Copied CD will track recording but no sound
When the CD was copied, a copy protection mechanism may have stopped the audio from being recorded. Essentially, playback of the original is normal, but software prevents recording by sending only silence, for the duration of the track, to the recording device.
Windows Vista, or newer, does this if you try to record from a streaming service (Rhapsody, Spotify, etc.) or directly from audio being played from a file.
If this isn't the case, try ripping the CD with a different program and re-burning it.
I don't know how it was copied (or ripped), so I can't give you a definitive answer.
Apr 23, 2016 | Audio Players & Recorders
Can copy from analog sources, but can't copy from digital source, eventhough the signal is monitored. The display says "can't copy".
Media
The unit requires Digital Audio CD-R or CD-RW media for
recording. Computer CD-R or CD-RW discs do not work with
this unit.
Serial Copy Management System
This unit is in compliance with the Serial Copy Management
System standard. This standard has been established to
restrict digital-to-digital copying to only the first generation.
The basic rules governing this system are as follows:
Rule 1
A digital recording is possible from a digital source such as a
CD, DAT or MD onto a recordable CD-R, CD-RW, MD or DAT
through a digital input connection. However, further digital
to- digital recording is prohibited for the second and later
generations.
Rule 2
When an analog source such as an analog disc or FM
broadcast is digitally recorded by using a CD-R, CD-RW, MD
or DAT, this recorded source can be digitally recorded on
another CD-R, CD-RW, MD or DAT. However, further digital
copying is prohibited.
Download the manual "cd-rw880_ef_manual.pdf" on the page linked below:
Download free pdf for Teac CD RW880 CD Player manual
Aug 22, 2013 | Teac CD-RW880 CD Recorder
Record in real time, drop markers then burn to cd.
I copy cassettes on my CD-R sometimes and I never know exactly where the cue points will be so I just make the digital source onm a CD-RW with rough manual tracks marks on the first pass with no stops.
Then I digitally copy that CD to another after I find out where the cues should best be placed, marking them manually as they come up. Then I recycle the source CD-RW.
Apr 28, 2010 | RCA CDRW120 2-Disc CD Recorder
Opc when recording then it stops
You don't define OPC...
One problem is if you are trying to copy material that has imbedded copy protection some recorders will stop, blocking your attempt to copy.
Another problem MIGHT be using wrong speed media.
Apr 20, 2010 | Sony RCD-W1 2-Disc CD Recorder
Can't finalize after recording, disc error
So are they always CD-RW?
I have a Pioneer PD509 which is a spittin' image of the HHB CDR830 but tied down to use CD-Audio discs only.
My experiece with Rewriteable Media has been that they don't hold up to multiple uses. I used them to make quick 'n' dirty dubs of cassette audio then worked it into a polished copy with proper track marks and sweetening later for copy over to a CD-RA. After a few passes I'd start getting audible problems when copying off the -RW's, so I routinely just use them about 5 times. With two DVD players and a Blu-Ray I sometimes get through the errors on one of them for one final digital copy and then I can them.
BTW: you may want to try the failing disc in a DVD player. Mine will play through an unfinalized CD but can't cue up to anything. So if the recording is vital you might retrieve it that way. Just remember to pause the Recorder at the end of the last cut you want because the DVD will just crash right into the old data without changing track numbers or any warning.
Mar 04, 2010 | HHB BurnIt CDR830 CD Recorder
I want to record from vinyl record to CD i have the record what Digital audio CD_R DO I NEED I have bought Verbatim Digital Vinyl CD-R Recordable FROM **** SMITH Because that is what they told me to by at...
first you have to copy the records output to the PC, and then burn them to CD DVD. Those disk will be fine after you have recorded the vinyl to the PC. In audio form..
Jan 31, 2010 | Televison & Video
It wont let me record anymore
If you are connecting via toslink optical or coax digital chances are you are encountering SCMS (Serial Copy Management System). SCMS will prevent you from copying a previously copied DAT or CD. You will need a CSMS stripper or copy bit bypass to circumvent this. I am assuming you are not violating copyrights. Behringer Ultramatch 2000 is a good SCMS bypass machine, and they are easily found on the internet.
May 21, 2009 | Sony RCD-W1 2-Disc CD Recorder
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
RCA CDRW 140 dual deck CD recorder
READY
Place cd you want to copy in tray A (EVEN WHEN YOU WANT TO GET ONE SONG COPIED )
Blank Disc in tray B .
Program tacks in any desired sequence
Press the TIME SET / PROGRAM button on recorder or remote..."WAIT" appears then "01" flashes to let you know the unit is ready for the first track.
Enter the first track you want to program using the numbers buttons on the remote .
or SKIP / SEARCH button on recorder.
When the track flashes PRESS TIME SET / PROGRAM on remote or recorder.
to select it , "OK " appears
HOPE THIS IS HELP YOU NEED >> GOOD LUCK
I WISH MINE WOULD WORK IS DOWN AND OUT !
Oct 08, 2008 | RCA CDRW120 2-Disc CD Recorder
Recording
Connect the analogue inouts of the recorder to the monitor or tape outputs on the mixer.
Nov 27, 2007 | Denon DN-C550R 2-Disc CD Recorder
Sony RCD-W500C 5-Disc CD Recorder Logo
91 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
