Question about Philips 170S4FG 17" LCD Monitor
Hi,I have a LCD monitor Philips 19 inch Black. From time tot time,appear one error... NO VIDEO INPUT , and then is made black and appear "Entering sleeping mode" . What I must do? Or for where appear that...Tyvm.
    Scholar:
  • 91 Answers
Check that the Video cable (VGA or DVI) is not damaged, if you move it does the screen go on and off?
If not then the circuit board inside the screen is faulty and needs reparing
Posted on Apr 05, 2011
After some time LCD going to black screen till again power on
Do you have a Video Picture for a short time and soon after the picture drops out and the screen goes black?
If so, when the LCD gets warm/hot a Diode shorts out and the screen can shut down. If that is the case, you may need to replace the screen. A technician needs to test the circuit board to see if a short is occurring in that hardware as this could be another fault.
Dec 25, 2013 | HP W1907 19-inch Widescreen Flat Panel LCD...
MONITOR IS BLACK, POWER LITE IS ON, I CAN HEAR COMPUTER SOUNDS
By computer sounds do you mean the sound of fans and hard drives spinning? If there are no loud distinct beeps indicating a startup error (See Post Beep Codes), then I would check the following.
I'm assuming you mean the power light on the monitor is on. If that is the case then it is one of two things.
  1. The monitor is not set to the correct input source.
    • Make sure you go through the monitors menu and select the input. Example
  2. The video cable to the monitor has a bad connection.
    • Make sure the cable is connected properly
    • If repositioning the cable differently restores the image than the cable is most likely failing. Try replacing the cable with known good one.
    • If the cable is good it could be a problem in the jack on the monitor or the computer.
      To repair this would require disassembling the monitor or computer and replacing the jack.
      However, most computers and monitor have more than one type video input/output. Try the other input/output jacks. Example
Nov 16, 2013 | Impression Products Impression 9LSP 19"...
I connected my acer monitor to my dvd - screen appears the switch to amber light black screen
What kind of the adapter are you using to connect the DVD video output to the monitor VGA/dvi INPUT? Need more information.
Mar 26, 2011 | Acer AL1916W 19" LCD Monitor
No video image on LCD but OSD works
Sounds like you may have a bad video cale or a dmaged or bentpin in the connector, remove the cable from the monitor and look at the pins on the connector
Dec 14, 2009 | Philips 170S4FG 17" LCD Monitor
I get a "invalid input" message on T900HDA 19 LCD screen
change laptop or pc to higher resolution like 1024by768 as well as 75hz
Jul 02, 2009 | BenQ 19" lcd black 1440 x 900 19 inch LCD...
Sometimes when I change the settings profile from "User" to "Graphics," a black border appears on the screen and some of the viewing window is off the screen. Usually when I click the "Graphics" profile...
All LCD displays have an "Auto" button press it and see if that fixs it. should be aparent what it does if it does it. but basicly it alines the picture with the screen. when you change back to user profile you may need to press it again.
Dec 21, 2008 | Acer AL1916W 19" LCD Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Open Questions:
Philips 170S4FG 17" LCD Monitor Logo
209 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
