I am using accer-5745 laptop. i install win7 & drivers after restarting my mouse pad doesn't working. before installation drivers it works , i reinstalled drivers. but it doesn't work, mouse pad works before installing os at confiuration windos stage of win7 installation but after installation it doesn't work . please give me solution.
    Scholar:
  • 83 Answers
The sodtware/driver may not be compatible with your new Operating System. Check your product website if they have a driver for your new Operating System
Posted on Apr 05, 2011
Mouse pad doesn't work on windows 8
I press <alt> F5 and it will turn on/off the mouse pad!!!
Feb 17, 2013 | Acer Computers & Internet
How di make my mouse work
usb mouse or mouse bad ?
Look at the type of mouse you have.
To date, there are three types of mice: the USB mouse, the PS/2 mouse and the Bluetooth mouse.
USB mice connect with a USB adapter, which has a rectangular shape. Conversely, the PS/2 mouse uses a PS/2 adapter, which is round.
Finally, there's the Bluetooth mouse, which has no external adapters.
Plug the mouse into your machine.
Now, how you do this will depend on the mouse you're using.
With a USB mouse, simply plug your device into your laptop's USB adapter, which will also be rectangular in shape.
For PS/2 mice, you'll need to plug it into a PS/2 adapter. Plug your mouse into the PS/2 end then plug the other end into your laptop's USB adapter.
And for Bluetooth mice, no plugging is required.
Install the mouse drivers.
If your mouse is not plug-and-play, you're going to need to install its drivers. To do this, insert the CD or diskette that came with your device.
The installation should occur automatically.
Pair your mouse, if using a Bluetooth mouse.
At this stage, non-Bluetooth mice are ready to be used.
However, if you are installing a Bluetooth mouse, you must perform one additional step: pairing it to your machine.
To achieve this, use your laptop's touchpad and right-click on your Windows screen. Select the option "Pair Device." From there, follow the on-screen instructions to sync your mouse with yourcomputer.
Place your mouse onto a mouse pad. Before using your mouse, you need to place it onto a mouse pad.
This should be done for all types of mice, whether they are wireless or trackball.
Otherwise, movement will be difficult
mouse pad
Examine your mouse pad.
Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether.
Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component.
Check to see if your mouse pad has been turned off.
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work,
Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area.
Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input.
It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad).
Then, click on download.
Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again.
hope this helps
Sep 09, 2012 | Compaq Presario CQ57-339WM
Jumping cursor on laptop
clean the mouse pad ,,, if doesn't work uninstall pad's driver and re-install the correct one... some laptops comes with joystick if yours have one clean it with a contact cleaner or disable it by unplugging it's cable ,,, if it didn't solve your problem replace the mouse pad or use a usb mouse ... :)
Mar 06, 2012 | Sony Computers & Internet
Accer emachine e725 touchpad mouse not working............
Plug in a USB mouse and then try to download the Acer driver for your touchpad here: http://support.emachines.com/em/driver/index.html
If you install the newest driver off of the Emachines website, and the touchpad still doesn't work, then it is possible that the touchpad has gone bad.
Nov 15, 2011 | Computers & Internet
My touch pad wont work
please try to un-install and re-install the driver for the touch-pad. if that doesn't work then you have a bad touch-pad and it needs to be replaced. or you can use a usb optical mouse instead. refer to local service tech for parts
Aug 25, 2011 | HP Pavilion zv5000 Notebook
Mouse frozen which keys to use instead my lap top works how I am able to write now. My Desk top computer mouse is frozen?
If you were using a physical mouse (instead of a track pad), then try a different mouse.If you were using the track pad, get a USB mouse and plug it in. If it works, then continue to use the USB mouse. If no type of mouse will work at all, it is a software issue. If rebooting doesn't fix the issue, you may have to reinstall windows. If you are using a mouse with a driver that was installed using a disk, try uninstalling that driver from the add/remove programs window (programs and features wind on vista and later).
Apr 29, 2011 | Computers & Internet
My acer ASpire 2920z mouse pad freezes when I plug in the charger. I have to unplug the charger to use the mouse (Both plugged in and mouse pad) and this is inconviniences alot. What can I do?
Hi there, please hit FN+F7 key at a time for unlocking the key pad. After that, If its not working then follow the below instruction.
A)
1. Restart the PC and repeatedly hit F8 until you have a menu in front of you.
c1fdd55.jpg 2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
If not working then try these step.
B)
Uninstall the mouse driver from the device manager.(Right click on My Computer then select manager. A window will open , there you will see device manager. Now select the mouse, then select the mouse device. uninstall from there.) Now restart the laptop. When you see all the icon is ready for work, then put your driver installer DVD & run the driver set up. When its finish, restart your laptop again. Your mouse will be ready for work again.
After these, if you again face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
Feb 15, 2010 | Computers & Internet
Laptop mouse not moving properly
If u r talking about the Mouse pad on ur laptop, then i guess u should reinstall the driver of ur touch pad..
U can do so by going to Properties of my computer
Open device manager & select mouse
Now simply uninstall the device & restart your system..
if u cant restart it then simply press F5 inside ur device manager tab. It will show a pop up named, NEW HARDWARE FOUND.
Let it install it... Its ur mouse ( Touch Pad) & after it installs its driver, restart ur system
now check out whether it works or not..
Hope this works u out..
If u like my post please rate me up..
I really need some good ratings..
Thanks !!!
Sep 17, 2009 | HP Pavilion dv6000z Notebook
Touch pad scrolling is not working
check the device manager to see if the device has been found then check the driver status ? Not shown in the Device Manager , has been turend off in the bios ? do a add hardware to see what it finds ?
Jun 13, 2009 | Acer Aspire 5735 Notebook
Keyboard and mouse pad not working accer 5100
try removing the battery and restart only using the mains lead. it worked on my aspire 5600
Nov 03, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
