Question about General Electric Refrigerators
I have a GE side by side PSG29NHSACBB serial number LH438193 There is a low pitched howling/humming noise coming from the freezer compartment. The noise is not constant but cycles on and off in a alleatory manner. It will make the noise for a long period of time then suddenly stop and work normally (that is with the ventilator working in a pretty low noise) then resume again after several minutes or hours. The only way to permanently stop the noise is to turn the freezer thermostat control to off and leave it there. Alternatively, if I turn it to off, wait a few seconds, then turn it on again the noise stops for a few minutes (even though the air is circulating) but eventually it starts again. I have had changed, by GE's technical assistance, the main control board, and this solved the noise for a while (almost 11/2 years) but now this low pitched howling/humming noise is back. I paid good money for this change, and I am not willing to pay for a second new board and fan motor (this is what my GE service man told me)
  • 5,370 Answers
The noise you described is indicating towards the fan in the freezer compartment. If this fan motor gets weak or the fan blades gets obstructed then this type of noise is heard. First check, if there is any over ice frost getting build up on the evaporator coil. If you see, this over ice frost getting build up then, yes, due to ice frost getting build up, the fan blades gets obstructed and this makes noise. But if the ice frost is not there and fan blade moving freely, then its fan motor issue causing this noise. The fan motor has to be replaced. If you see, too much ice frost collected there, then its defrost related issue. First try manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Posted on Apr 06, 2011
Gsh22kgrecc freezer compartment howls
Check to see if fan is loose also check to see if there is ice buildup inside and blade is hitting it
Jan 24, 2018 | General Electric Refrigerators
There is a low pitched howling/humming noise coming from the freezer compartment. The noise is not constant but cycles on and off every 15 minutes. It will make the noise for a period of time then suddenly...
The evaporator fan motor likely needs replacing. The fan is located behind the rear panel in the freezer section. It may just be loose or rubbing but usually it just needs replacing. Here is a link that should help Evaporator fan replacement You can also enter your model # for diagrams and illustrations of your specific model.
Nov 17, 2010 | GE GSH25JSRSS Stainless Steel Side by Side...
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Low hum or buzz in fridge/freezer (mostly from the freezer side)
Hello, the solution was the ASM control circuit board, ordered one online for around $100 and replaced it
Thanks
May 30, 2010 | Refrigerators
Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
Dec 17, 2009 | GE GSF25XGR Side by Side Refrigerator
Noise high pitch noise from the freezer on my side by side
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whining/howling on freezer side
Need to unplug the refrigerator and remove the cover inside freezer compartment. Sounds like the evaporator fan is hitting something and we need to resolve this as soon as possible. Thanks Sea Breeze
Mar 26, 2009 | GE Refrigerators
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Noise
this fan is a variable speed and is controlled by a board in the rear of the unit. your bearings maybe going out. The fan will ramp up to speed depending on the call for cooling the Thermistors is asking for
May 20, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
190 people viewed this question
Top General Electric Refrigerators Experts
Van Allen II
Van Allen II
Darrell
Day Coker
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
