Question about Canon NP 6230 Copier
Can't get it to make copies. I need it to show "letter" size when choosing the size parer...it shows A4.
  • Canon Expert
  • 1,326 Answers
You may have a piece of paper jammed behind the paper tray? I would take the paper trays out of the copier and look inside to see if there is paper jammed toward the rear of the copier..... There are switch's that till the copier what size paper is in the tray. It can also be a small tab on the back of the paper tray is not adjusted correctly? Good Luck
Posted on Apr 06, 2011
How to fix id card fuction
first entered in SPECIALFETURES then
IMAGE COMBINATION then (Machine Ask Original Paper Size)
Select A5R (if the LTR Size Show tuch the AB botton)
Select 2 on one then select A4 paper tray
Then Screen Show Special features
DO NOT TOUCH RESET or Any botton
touch MODE MEMORY select M1 touch STORE then done then OK
Press the Additional Function Bottoan
touch Copy Setting
touch Standred key 1 setting
(in this Window show many botton)
choose modememory Select M1 Select OK
afterthat your home screen show M1 on Bottem Left corner when you touch ID CARD COPY Feature activate Scan 2 Time Front /back Print on Combind one Side Enjoy!!!!
Feb 25, 2015 | Canon ImageRunner 4570 | IR4570 |
H2
Paper size is set for a different country. Assumimg your in the US. Have to go into admin mode Maintenance mode set paper size to letter or legalnot B4 or C5 or A3 or A4 theese are metric size paper.
Mar 28, 2014 | Minolta DiALTA Di183 Copier
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Can I scan legal size paper with the Canon MP 240
Hi
You can scan the largest size of paper that will fit on the glass area of the scanner (the platten).
If your legal paper fits in this area or, at least the text printed on it fits well within the borders of platten, then you can scan it.
Your scan will show you a preview of the image scanned so you can see if all the text has been scanned from the original document before you save the scanned image on the computer or copy print it.
Legal Paper Size is: 8.5" x 14" (216mm x 356mm)
A4 Paper Size is: 210mm x 297mm
Letter Paper Size is: (8.5" x 11") 216mm X 279mm
This printer's Scanning Width is: A4/Letter
This printer's Scanning Length is: A4/Letter
I hope this helps.
Aug 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Always showing the manual feed option when we printing. We would like to set it as automatic printing. How can we do that in default. Please help. We checked all the menus. example: in system set up paper...
If you are in Canada or US then you need to set the default paper size to Letter not A4. Most if not all software you use likely sends the print job in letter format. Because the printer is set in A4 it stops and waits for that size.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
Print jobs stick in prnt queue
A lot of users have no idea how to change the MS Office default from US to UK .. so they have US spellings and US paper sizes (known as 'Letter' sized) .. and (of course) any Document that started life in USA keeps it's size until some-one changes it ... since Letter size is almost the same as A4 no-one cares UNTIL they come to print it ...
I'm sure you can guess the rest :-)
Yes, the Printer is looking in it's feed tray for Letter sized paper .. yes, Letter doc's will print just fine on A4 and most printers have a setting somewhere that lets it use A4 when asked for Letter (often called "automatic A4<>Letter convert" or some such)
NB. when time permits, perhaps the unfortunate users can have their MS Office apps. set to UK mode :-)
Mar 17, 2009 | Dell Office Equipment & Supplies
Paper size
Try setting the a4 original on the glass instead of the document feeder.  Load the a5 paper into the tray and try copying that way.
Sep 09, 2008 | Sharp AL 1631 Copier
"always getting check paper size"
the paper size you are using is incorrect.
1- when you take out the tray is the the paper snug in the tray? is the paper adjuster set to LETTER, is there a switch for custom and letter? is it set to letter?is it set to letter in the menu?
Dec 08, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Canon MF3240 printer error message.........
I think I solved my printer problem: Chang the paper size to LTR in the printer panel. then go to compter printer setup and choose printing preferences and choose page setup and chang the paper size to Letter (LTR) also. hope this is helpful.
Nov 13, 2007 | Office Equipment & Supplies
Canon NP 6230 Copier Logo
43 people viewed this question
old marine
old marine
