Question about Dacor Preference PO130 Electric Single Oven
I have a Dacor PO130BK oven. The screen says it is "locked". How can I unlock it? I do not know how this happened.
Oven started making a clicking noise after I started the self-cleaning process. Continued until "F8" flashed next to the clock. When canceled was pressed, the clicking started again. As a...
F8 means a fault on the door locking switch.
Something may be preventing the door lock from operating properly.
The solution is to have the door lock switch and wiring checked over.
Dec 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
Put oven through self clean for 2 hours. Oven
What has happened is IF the temp gets to hot in the electronic controls area, an in line fuse/limit burns out and shuts down everything.
I have a DACOR tech sheet HERE
So what I think is happening is the in line fuse in the wiring harness could be blown. You won't know till you or someone checks.
Jan 15, 2010 | Dacor Ovens
The oven says locked. How do you unlock it?
Hold the "Cancel/Secure" button for several seconds until it beeps.  This is how you turn the lock on and off.
Dec 06, 2008 | Dacor ECD230 Epicure Electric Double Oven
Dacor ECS136 Control panel just beeps but does not work
i am having that problem with my maytag one. the only thing i can do is unplug it and quickly press bake and set the temp and time length. mine says its locked though. i am trying to figure out how to unlock mine.
Oct 30, 2008 | Dacor ECS136 Epicure Stainless Steel...
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
Dacor CPO130W F4 fault
f-4 on decor ovens mean the oven temp sensor is bad. replace the oven temp sensor and it will be fine
Nov 27, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor Wall Oven Epicure EO130
I would call the store you bought it from or dacor as it is under factory warranty...
Aug 31, 2007 | Dacor Millennia MOV130 Electric Single...
Ovens Logo
21 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
