Question about Sony Televison & Video
Ok here you go, I needed to replace my lamp on my Sony KDF-50E3000, lamp XL-2500. Easy replacement, however now only the picture is HD and any words, at the bottom of the screen are blurry. The blurr comes in and out at times. Originally I took off the whole fron of the screen as I thought this was how to replace the buld as I could not find my manual. Do I need to clean the mirrors inside the TV? Thank you
  • paul_aldrich Apr 05, 2011
    dduncan774
    So how would one re-align the fresnal? Is there a manual for this? I think I may have bumped it, as I thought the mirror was the bulb.
  • 760 Answers
Only getting HD has nothing to do with a lamp change. I would start by seeing if your antenna settings got changed. For example from cable to over the air antenna. As far as the blurry words on the bottom of the display, I think you didn't get the screen lined back up all the way.
Posted on Apr 05, 2011
Testimonial: "Wow So far so good will see how the advice helps"
  • 1 more comment
    Thank you, but all the screws went back in, could there be dust at the bottom of the screen? Was thinking of pulling to back off and wiping both the screen and mirrors down? Bad Idea ? --
    When you mention line the screen do you mean the front of the TV? Or could I have bumped the mirror inside and behind the screen? Yes AMATURE
  • David Duncan
    David Duncan Apr 05, 2011
    I am sure the screw holes lined up fine, but every time you take the screen off you run a risk of needing an alignment. The fresnal actually bends the light to fit the screen and does not take much movement at all to get it out of alignment. I did notice you said the blurr comes and goes so I don't think this is the case.This is hinting to me that it is in your broadcast and not the set. Of course I could be wrong. You could try to reset your TV to out of box condition and start from scratch. As timely as that sounds it can prove to be a great trouble shooting asset.
  • David Duncan
    If you are sure that you might have bumped the mirror out of place a little, you can loosen the screws that hold it in place a touch and make sure it slides in to its track all the way, but as I stated, Your blurr comes and goes. If it was an alignment issue, I would think that the problem would be there constantly.
I have a Sony KDF-50E-3000 that takes about an hour to warm up before the picture will come on. I replaced the bulb twice. Once with an after market product and then with a Phillips bulb. It does the...
If the lamps have been ruled out then it MAY be the Ballast that powers the lamp, no easy way short of replacement of that board to know, You might want to contact Sony to see if this is a known issue in their database for this model.
Dec 11, 2012 | Sony KDF-50E3000 Television
My kdf50e3000 won't show picture or audio. The green light will remain on and then start blinking and then back to being on. What could this be? It started today when I turned on the tv.
It seems lamp in tv is dead and requires replacement.
When did you replaced lamp last time in tv?
If it has not been replaced since last 2-3 years then check lamp and replace it. Lamp replacement is user level repair and written in user manual page-43
Sony Accessories Store has related lamp for $200
Hope this will help.
Thanks
Apr 27, 2011 | Sony KDF-50E3000 Television
2007 Sony TV KDJ-50E3000 keeps cycling on and off
If lamp in tv has not been replaced in last 2-3 years then it is time to replace it as tv shuts off and turns On itself is symptom of dying lamp that need to be replaced.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Mar 28, 2011 | Sony KDF-50E3000 Television
How many projection bulbs does a sony kdf-50e3000 have
Sony KDF-50E3000 is LCD Rear Projection tv that has one lamp as back light source and optical unit (light engine) generates image that projects on front screen of tv, it is similar to multimedia projector technolog.
Lamp part number is F93089000 XL-2500 utilized in this model.
Thanks.
Feb 17, 2011 | Sony KDF-50E3000 Television
Sony KDF E42A10 picture loses quality.
It sounds Lamp is weak and causing darker picture.
How old is this TV and did you replaced Lamp recently?
If lamp has not been replaced in past 2-3 years then its time for new lamp, XL-2400 available in Sony Accessories Store and lamp replacement procedure is written in user manual.
Thanks.
Nov 05, 2009 | Sony KDF-E42A10 42 in. LCD Television
WONT STAY ON. IT TURNS OFF BY ITSELF ABOUT EVERY MINUTE OR 2
I would suggest replacing your lamp. It's very easy to do and it explains how in the owners manual. Lamps are readily available online or try your local TV repair shop.
Aug 14, 2009 | Sony KDF-50E3000 Television
TV comes on and off
If it is Sony KDF-50E3000 TV then its symptoms of weak Lamp that requires replacement.
You can purchase required XL-2500 Lamp from Sony Accessories Store.
Always buy Sony Original Lamp for your TV and avoid aftermarket / cheap lamp.
Thanks.
Apr 27, 2009 | Sony KDF-50E3000 Television
Sony Grand WEGA KDF-70XBR950 70 in
You need a new projection lamp.......(XL-2100 replacement DLP lamp)..... go to this web site to get the lamp you need for your TV model KDF-70XBR950 70inch----
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11040980
------ This web site shows you how to install it yourself. ----
http://guides.fixyourdlp.com/sony/XL-2100U.php    --------- I strongly suggest that you get a SONY manufactured replacement lamp NOT a cheaper lamp from another manufacturer... it costs about $200.
Adelaide B.
Oct 30, 2008 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony KDF-E50A10
You may want to have the optical block checked out. Usually when you see spots or blotches of color it's due to a malfunction of the Opt. Block assembly.
Feb 22, 2008 | Sony (XL-2400) Projector Lamp for...
Televison & Video Logo
83 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
