Question about Air Tools & Compressors
The threads are stripped on the valve that controls the air
    President:
  • 1,388 Answers
Stripped adjustment on pressure regulator is common due to over tightening and adjusting while under pressure. If you let out all the air from the tank, the adjustment may work. If not, replace the regulator with a universal regulator from ebay or www.grainger.com. When ordering, make sure that the port sizes are correct. A universal pressure regulator will cost about $20. Some regulators are built-in to a manafold and are more expensive. For temporary measures, you can obtain air from the tank by connecting fittings to any available entry into tank. Example, remove the safety pop valve (usually 1/4 npt) and install a tee fitting allowing one port to reconnect safety and the other to install quick disconnect for air. This method will give you full tank pressure. A simple regulator can be installed between the temporary tee fitting and the quick-connect and it will function just fine untill you have time to work it into the control panel. Good luck
Posted on Apr 05, 2011
Needle valve in an outboard 1957 Johnson
No, check threads on needle and carb. Ensure they are not stripped or cross threaded.
Sep 04, 2017 | Boating
How to remove sprocket and clutch from ms250 stihl chainsaw
Removal>
  1. Remove the clutch drum/chain sprocket
  2. Remove the air filter
  3. Take out the shutter.
  4. Pull boot off the spark plug.
  5. Unscrew the spark plug.
  6. Close the decompression valve, if fitted.
  7. Push the locking strip 0000 893 5903 into the cylinder. (Piston Stop)
  8. Unscrew the clutch from the crankshaft clockwise (left-hand thread).
Installation>
  1. Screw on the clutch and tighten down to 50 Nm (37 lb.ft).
  2. Install the clutch drum / chain sprocket .
  3. Remove locking strip from the cylinder.
  4. Insert spark plug and tighten down to 25 Nm (18.5 lb.ft).
  5. Fit boot on the spark plug.
  6. Fit the shutter so that its lugs engage the recesses in the handle housing.
  7. Install the air filter
Feb 22, 2015 | Garden
Repair shop says spark plug was stripped, had to pull off the head of 2006 kawaski volcun 900. Shop says spark plug was sideways & all 4 valves are leaking, so needs a new head.
Not necessarily-- plug holes can be reclaimed by using a product called heli-coils . These are threads that when placed in a pre tapped hole ( stripped thread made oversize) and are of stainless steel and make the finished product the same as the original
valves can be ground again and seat inserts can be replaced or ground again to provide a new seat for the valves
Find your self an accredited engine reconditioning engineer shop and get a second opinion and a quote before you buy a new head
Aug 20, 2014 | Cars & Trucks
Our centurion pool pump motor Model B128 replaced less than 1 year ago. Pool company has to replace the impeller twice. Is this common? I believe the pool co sold and installed a used pump instead
Broken impellers generally are not caused by the pump's motor. Impellers usually fail due to back pressure from the filter when the pump shuts off. Air in the filter is compressed while the motor runs, on your pump 12-15 psi. or a bit higher.
When the motor shuts off that compressed air forces water back to the pump, sometimes with enough force to loosen (or completely throw off) the impeller. If the impeller is loose when the pump starts up again it will instantly re-thread the impeller and strip out the threads.
Check to see if you have a suction leak. After the pump has turned on, bleed the air out from the air relief valve on top of the filter. After the pump has run for a while open the air relief valve and see if air comes out. There should be no air, or just a little.
I have seen this back pressure strong enough to blow the skimmer basket up onto the deck.
What make and model of pump and filter do you have?
Feb 22, 2013 | Pool & Spa
Where is the idle air control valve
Here is a web site to show you a picture of what you are looking for: http://www.theautopartsshop.com/auto+car-usa+parts/ford+focus+idle-air-control-valve.html
Here is how to fix it:
  • Unplug the electrical connector on the IAC valve located on the back of the throttle body near the firewall. No tools are needed to unplug the connector. Squeeze the release tab on the plug and pull to remove it.
  • Unbolt the two 8-mm attaching bolts attaching the IAC valve to the throttle body using an 8-mm socket and socket wrench from the socket set. Remove the IAC valve and gasket from the engine compartment.
  • Position the new valve and gasket in place on the throttle body, and bolt it to the throttle body using the 8-mm bolts and the socket and socket wrench. Avoid over-tightening as the throttle body is easily stripped out by over-tightening the fine-thread 8-mm bolts. Plug the electrical connector into the new valve, and push it on until it snaps into place.
  • Turn the ignition key to the run position but do not start it at this time. Unplug the electrical connector once again, and turn the key off.
  • Start the engine, and adjust the minimum air rate by turning the adjusting screw located on the throttle cable side of the throttle body until the idle speed is 650 rpm plus/minus 50 rpm. Turn the engine off, and plug the electrical connector back in--pushing until it clicks into place.
  • Feb 04, 2011 | 2000 Ford Focus
    I have a 5 ton goodmsn heat pump it only blows cold air the heat doesnt come on have a new heat strip in it but still blows cod air
    Heat pumps require a reversing valve for heat operation on the outdoor section, a control signal to a "O" terminal or orange wire is required for heating and cooling depending on the thermostat and out door unit requirements. The thermostat also has to be heat pump type for the system to operate heat for electric system with heat strip, two stage electric heating.
    Jan 31, 2011 | Goodman CKL60AR60 Air Conditioner
    How do you replace the regulator valve on a husky pancake air compressor? Mine just spins and will not allow me to get air to the hose
    I could not find parts for my husky compressor and had the same problem as you describe. I went to lowes and purchased fittings to draw air out of the safety port. Remove the safety pop valve and install t-fittings to allow you to reinstall safety valve and also a quick connect. If you want to be able to regulate the pressure, install a simple pressure regulator before the quick connect (also avail. at lowes). This remedy is not pretty but sure works great and simple. Problem with husky regulator is stripped thread /knob. Sometimes you can turn the knob if you drain air from tank; this will release the spring tension on the regulator knob.
    Dec 31, 2010 | Electric Air Tools & Compressors
    What goes in the small hole on the top of the main compressor cylinder on a 2340L5? Air is escaping and it will not pressurize the tank.
    There should be a small bolt in the top center of the head. If the bolt is missing you will need to remove the head only and inspect the valves and valve plate. This bolt screws into the valve plate and holds the assembly together. The bolt may have just broke or the threads in the valve plate stripped out.In either case they need to be replaced!
    Oct 18, 2010 | Ingersoll Rand - Rand Type - 30...
    Stripped connection at the cold water intake into washing machine
    If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
    If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
    Let me know if this helps.
    Jan 22, 2010 | GE Washing Machines
    Steam valve stripped. The seam valve does not shut off but remains in open position. Simply spins to left when attempt to turm ofs. Saeco Aroma.
    Hi
    If the valve is stripped then there is damage to the manifold too. You need to replace both, and when you reassemble the valve into the manifold lubricate the valve threads and it will prevent this.
    Nov 19, 2009 | Saeco Aroma Espresso Machine
    Air Tools & Compressors Logo
    177 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    JOHN LAPIER
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
