Question about Dryers
Need to find schematic for whirl pool dryer model number LER7620LWo. need to install a new heating element.
    President:
  • 1,273 Answers
Hello. W/D here.
Here's something better; exploded diagrams, parts lists, and manuals. Enjoy.
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dryer-Parts/Model-LER7620LW0/1198/0151200?searchedModel=LER7620LWo&blt=11
Best regards, --W/D--
Posted on Apr 05, 2011
  • clock49 Apr 05, 2011
    thanks for the help woobie dogyes that helped. clock49
  • Dryers Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
This is a 29 inch dryer and the manual I am going to pass you is for a 27" dryer. Do not worry the steps are exatly the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
See page 31 of the manual for the heating element.
Note you must remove the toe panel per page 20 (Bottom of page) using the link above to gain access. POWER MUST BE REMOVED from the dryer before attempting this.
The video below will also help you.
Thanks for choosing FixYa,
Kelly
  • Dryers Master
  • 3,361 Answers
Hwant schematic for Maytag dryer model YMEDE301YGO
Go to Partselect.com. they will ask for model number and serial number of your dryer. They have every single little part for appliances but better yet they have video's on how to make the repairs. They also have schematics for every conceivable appliance made. the prices are very reasonable and the customer service is top notch!
Mar 05, 2015 | Maytag Dryers
WHY WOULD IT NOT BE HEATING UP
This means your heating element has burnt out. Usually they consist of a coil, much like you can see on a hair dryer, in line with the air intake. Most common cause is the coil burning out due to excess lint and severing itself. When the coil breaks electricity cant travel from positive to negative so the coil stops heating up. Look online, try sears, type in your model number followed by - heating element - . You should be able to find your model number in the manual or by searching the name of the dryer. If you get the heating element and pay someone to install it, you should not have to pay more then getting a new dryer.
Nov 08, 2013 | Dryers
I replaced heating unit in whirl pool supreme 7 cycle and there is still no heat any ideas
You will need to check the thermostats on the unit. What is the model number of your unit?
Apr 25, 2012 | Whirlpool Dryers
How do i find the part number for a new heating element
First find the Mfr/Model number of your Dryer, and then phone your favorite local
major appliance parts store and ask them what's their price and part number for a
replacement heating element for your Dryer. Then you have 1 price/pert number for
one replacement heating element (from one Mfr that may not be the manufacturer of
the dryer itself). Phone another major appliance part store, and ask them the same
question, and you'll have another price/part number, pick the one you like best.
Then, post another question on FixYa, about how to install it - I (or you) may
then hunt down YouTube videos on how to install a Dryer Heating Element.
Apr 11, 2011 | Dryers
Need a heating element for a whirl pool dyer
try REPAIR CLINIC .com can order from them!
Dec 31, 2009 | Whirlpool GEW9250 Electric Dryer
Whirl pool gas dryer mod ggw 925opw3 will not heat up and dry sometimes at start up it get hot but only for about five min then you can feel cool air stat to com out the outside vent???/
It sounds like you could have one or more issues here. please be advised that only a gas technician should work on gas units. There are solenoid coils that are used in gas model dryers they energize the gas valves allowing gas to flow through to the element igniting it. if one or both of these are faulty you will experience a on and off heat problem. part numbers for the solenoids are 694540 and 694539. another possible problem is that you cycling thermostat located on the blower housing is faulty which gauges the temperature of the air coming from the gas flames. If this is faulty it will not receive the correct temperature reading, therefore not calling for any.part number for the cycling thermostat is 8573028.hope this helps
Thanks
Oct 12, 2009 | Whirlpool Dryers
Dryer does not go past wet cycle
if your vent hose is clogged, your element most likely burnt open
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moisture sensor does not seem to work
your heating element may be bad if your cycle completely finishes and the clothes aren't dry. If
Jan 28, 2009 | Dryers
Whirl Pool Dryer Model # LGR7646DQO
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 29, 2008 | Dryers
Dryers Logo
564 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
