Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore side by side not getting cold
My side by side is not as cold as it should be. I have the frezer and the fridge both turned to the max and I am 7 degrees away from being in the danger zone on the fridge side. It was transported on it's side so I don't know if that makes a difference. I cleaned around the coils and the stip between the doors feels a little on the hot side. The model number is 50562992 and the serial is sk4134293 and the type is c25ssa00
  • 120 Answers
Check the condenser motor at back of unit if is not running it will get hot in the middle section and it wil not cool properly
Posted on Oct 15, 2008
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
There is frost buildup on back wall of frezer fridge or frezer dont get cold enough
my fan blade had slipped down and was rubbing makeing a noise and fine particles of white dust was at the rub point. Pushed the fan back up drop of super glue and lubricated the motor. works great!
Jul 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
The refrigerator is not staying cold. the freezer works fine. we tried the settings to no avail. any advice?
Quick temporary fix - defrost the freezer (inside frezer lower back) it is probably full of frost/ice - this prevents air flow and therefore no air enters fridge side. common failure due to bimetal defrost thermostat failure ($20) - replace part for permanent fix
Aug 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore fridge not get cold enough and coils icing again
check all heaters on frezer side and check coil under unit to make sure clean ajust timer at the top of icebox side behind plastic plate where light bulb is it shold be onthe right side top turn until unit turns off then turn one half this is the timer for defrosting cycle.
Jul 23, 2009 | Kenmore Refrigerators
Fridge wont cool but frezer is fine
looks like you have a problem with the damper control. try to locate the sensor for the damper control and relocate it, if still not cold, replace it.
May 04, 2009 | Freezers
I have a Kenmore side by side fridge
check the freezer compartment at the back wall. see if there is frost build up at the back.
sounds like a fosted evaporator to me.
check also the evaporator fan in the freezer section if it is running.
if not, then there is your problem.
tnx 4 using fixya,
drcool
Nov 04, 2008 | Kenmore Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Kenmore Refrigerator Model #25357677791
stuck defrost timer/ thermostat. id go with both stuck because I'm looking at a diagram of your fridge now and there wired together.
i'd recommend changing both of them.
hope to be of any assistance.
Apr 26, 2008 | Refrigerators
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
221 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
