Question about ASUS HS1000W Wireless Headset
Please could you let me know how you transfer a call to another line whilst using an ASUS wireless headset? Also, how do you answer a call when you are not sitting at your computer.
I have a h350 how do i connect it
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
Apr 03, 2011 | Motorola Mobility H300 Wireless Headset
How to make auto answer incoming phone (hand free) with LG HBM 570 bluetooth headset in case driving car
Hi, LG HBM 730 Bluetooth Headset Wireless Headset does have the ability to auto answer a call. But it does that automatically (does not need settings for it).
Also you can set auto answer from your cell phone.I don't know the model of the cell phone you are using at the moment. So you will need to use the manual of the cell phone to know how to auto answer calls.
When you set the cellphones auto answer, then it will auto answer on your LG HBM 730 Bluetooth Headset Wireless Headset..
Have a nice day
Mar 02, 2011 | LG HBM 730 Bluetooth Headset Wireless...
I have a Motorola H350 ear piece I lost my inst. manual and do not have a pass key
Hi, If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Tips & Warnings
Feb 16, 2011 | Motorola Mobility H350 Wireless Headset
Blue tooth pairing code t055
Hi, you can use the below instruction to know to pair with blue tooth..
How to Pair (Connect) a Blue tooth Headset to Your Phone
So you've heard of this new thing called "blue tooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
Instructions
Things You'll Need:
* A Blue tooth cellular phone
* A Blue tooth Headset
Ok... Here we go.
On your handset, find the blue tooth menu.
On most phones, go to the settings menu, then to "connections" and then "Blue tooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Hands free" link. Select [look for new device] select this option, and hit "OK".
On Sam sung phones: **Blue tooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will now ask you for a "Pin" or "Pass-code", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or pass-code. I have never encountered a headset with a different number as a pass-code. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
If you turn off the phone, or headset, you can repair them again simply by going to the blue tooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
Tips & Warnings
Feb 03, 2011 | Cell Phones
I need Sony Ericsson J105a passcode for use bluetooth
Hi, How to Pair (Connect) a Bluetooth Headset to Your Phone
Instructions
Things You'll Need:
Ok... Here we go.
Tips & Warnings
T
Thanks for using fixya....
Jan 27, 2011 | Cell Phones
I would to have number of pin of motorola h 550
Hi,you can follow the instruction to know how to connect blue tooth and the pin to use for pairing your phone .
Instructions
Things You'll Need:
Ok... Here we go.
Tips & Warnings
Thanks for using fxya...
Jan 14, 2011 | Motorola Mobility H550 - Bluetooth Headset...
Having trouble connecting BT-K352 with I-phone 3gs
Instructions
Things You'll Need:
Ok... Here we go.
Tips & Warnings
Hope that helped..
Jan 12, 2011 | Just Wireless Bluetooth Headset Wireless...
Can i use the Plantronics Voyager 520 for my incognito phone and how do i hook it up?
Instructions
Things You'll Need:
Ok... Here we go.
Tips & Warnings
Jan 12, 2011 | Radio Communications
What is the passcode for jabra headset???
Instructions
Things You'll Need:
Ok... Here we go.
Tips & Warnings
Thanks for using fixya.....
Jan 12, 2011 | Jabra BT160 Wireless Headset
Just need to know how to set up have no manual
Instructions
Things You'll Need:
Ok... Here we go.
Tips & Warnings
Hope it helped.
Jan 08, 2011 | Plantronics Explorer 232 Bluetooth Headset
Open Questions:
See all ASUS HS1000W Wireless Headset Questions
ASUS HS1000W Wireless Headset Logo
186 people viewed this question
Top ASUS Radio Communications Experts
ray gallant
Brett Duxbury
Brett Duxbury
Caitlin Romagna
Caitlin Romagna
Level 1 Expert
Are you an ASUS Radio Communication Expert? Answer questions, earn points and help others
