I have a Roland HP535 digital piano. How do I fix a broken key (A above middle C)
  • 1138 Answers
SOURCE: I have a problem with a roland hp 147e digital
If it is in an area that you play a lot it might be the membrane contact strip that needs to be replaced. They come in sections and can be replaced with some careful work with the right parts if they are still available. If the membranes themselves are ripped they usually have to be replaced. If the contacts in the membranes are dirty they need to be carefully cleaned. In your case as it is a section of notes there may be a connector that has worked loose (not usual but possible). Further than that requires the schematic and tools and troubleshooting electronics experience. If you are not comfortable with tackling this yourself contact several musical equipment dealers that sell Roland products for their opinions and prices per hour for repairs. Also check piano tuners and repair places for advice. Hope this helps.
Posted on Aug 07, 2009
  • 1138 Answers
SOURCE: Have a HP 1700 Roland Digital Piano that has one
It sounds as if the membrane under the key needs to be replaced. It can be done with some careful work yourself but you might want to consider having it serviced by a Roland dealer as apparently the parts are becoming scarce. Hope this helps.
Posted on Aug 20, 2009
  • 5603 Answers
SOURCE: I have a Roland HP 101 digital piano however certain dont sound
White spirit is NOT what you should use. Mineral spirit leaves a residue film.
Use 99% isoprophyl alcohol.
ALSO inspect the contactboard for cracks by candeling with bright light behind it.
Posted on Nov 01, 2009
Testimonial: "bur isnt it strange that certain keys have stopped working? ie most the A keys"
  • 5603 Answers
SOURCE: My Roland Rd-500 has no sound....the factory demo
You either did not get the ribbon cable seated OR got it upside down.
If this cable is the flat ribbon with exposed solder plated points of contact, OFTEN those connectors have a latch to release by GENTLY moving tabs on eaither side in the direction of pulling the cable out. This lock MUST be moved out slightly to allow the cable to seat properly. The solder plated contacts will be FULLY into the connector when seated properly.
These cables ALSO can be inserted backwards and NO connection will be made.
Posted on Feb 14, 2010
  • 5603 Answers
SOURCE: How to remove piano keys from Roland KR 4700
You probably need to just clean the circuit board and the conductive rubber contacts. There are two per key to facilitate reading the key velocity.
Use 99% isoprophyl alcohol and Q-Tips to clean both the board and the rubber contacts.
A rod is inserted lengthwise to hold the hammer weights while removing the boards. Use dowels from each end inserted about halfway back between the keys and the weight rods. Use a 1/4 inch dowel rod.
You have to take out a few screws to remove the boards from the key assembly. Be careful of the cables.
Posted on Mar 17, 2010
Testimonial: "Thank you so much for your information. This gives us a clue. Can't wait to get this fixed. I really appreciate your help."
Do they still make the Yamaha CP-300`s
NO - try the
  • Yamaha CP4 Digital Stage Piano which replaced it.
  • A Roland Digital Piano
  • NORD
Apr 30, 2014 | Yamaha Cp300 Cp 300 88 Key Keyboard Piano...
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Keys on yamaha digital piano are sounding more than one note at a time how can i fix this?
The keypads can develop dirt , failure of pads which can result in such malfunctioning. If you are able to open the piano then carefully remove the keypads , clean the surface and reset.
this must solve the issue unless the pads/springs/mechanism are having fault.
Jul 05, 2011 | Roland Hp337 Digital Piano
Hi, I am undecided about which digital piano to buy: Yamaha Arius 141 or Roland F110? help appreciated, thanks, karol.
I have two Yamaha's and I will say they are maintainable. Almost ALL the weighted piano key models use a keyboard made by one company as I understand it. I can easily get service manuals for the Yamaha, not quite as easy for the Roland... same goes for repair parts. Your decision... listen to each and decide. Hint: Use a set of headphones to do the compparision rather than internal speakers as the orientation in a music store can drastically change the sound.
May 01, 2011 | Roland F110 Compact Digital Piano 4867
Mar 17, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
Oct 31, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Oct 05, 2009 | Roland Music
Have a HP 1700 Roland Digital Piano that has one key (first G to the right of middle C key) that is off.
Aug 18, 2009 | Music
Roland 3000 Digital Piano 88-Key Full-size weighted keyboard
It's not really for the faint of heart, but generally this is caused by gunk getting into the key circutry. Underlying the 3000's keyboard is a silicone pad with 2 contacts on it, the measurement between each being hit is the issue usually but yours just sounds like there's something in there causing a physical or contact obstruction.
What you really want to do is to remove the keys and clean everything but this isn't easy... You could try using 99% alcohol (from a pharmacy) to clean inside it which may well help you.
There's a good thread on a similar issue at:
http://www.electronicspoint.com/roland-hp-3000s-digital-piano-dodgy-note-t18946.html
Which may help you work out how to do the disassembly if you are brave, but I would start with pouring some alcohol in and poking it and hoping for the best 1st. It sounds crude, but it works amazingly well with some things.
Dec 29, 2008 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Roland HP2e digital piano and one of the keys has lost its touch sensitivity. It works initially but when it passes a certain threshold of loudness when played it goes to full volume on that key...
Just managed to fix key loudness problem on my sister's HP-2E after talking to the local Roland Service Center. Basically I had to remove all the rubbery strips under the keyboard, clean them and clean all the contacts on the keyboard PCBs with CO contact cleaner. Not a trivial procedure - 80 or so screws to remove and replace and a lot of parts.
It has completely solved the problem (apparently its not unusual on any keyboards). I have posted more details and a couple of pictures on my blog (http://web.me.com/iain_sommerville/Home/IainBlog/Entries/2009/4/20_Piano_Repair_2nd_Attempt.html not sure if that is a permalink - if it doesn't work go to http://sommerville.info and search for HP-2e).
A roland service center can fix this as well however it is pretty time consuming so they will charge you. They can also sell you replacement keyboard contact strips if cleaning them doesn't work. Hope this helps
Jun 21, 2008 | Audio Players & Recorders
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
