Question about Dell Inspiron 1000 Notebook
Abnormal shutdown, cannot restart
OOOkay, I know nothing about computers or their set up, so I am looking for the recovery or operating system disc. None are obviously the one I need: I have Drivers and Utilities Wireless, and 2 utilities discs: (for re-installing Cyberlink Power DVD andSonic My dvd) II sounds like with no recovery disc there isn't much I can do short of taking it in for repair, and since I've become disabled my funds are stretched, I fear this could k=lead to a fairly expensive fix. Thanks for your assistance.
    Genius:
  • 2,028 Answers
O.k. I did a little more research into a fix for this, and found a couple things that you can try and read. I also found that this could be that the hard drive has failed and may need to be replaced. Hopefully you will be able to fix it without replacing anything, but you will definitely need an operating system disc. The Stop 0x000000ED is an unmountable boot error code. This could be a bad connection with the hard drive or hard drive cable on the motherboard, so, you might also try removing the hard drive, and blowing out with air, or open the cases and check the hard drive cable where it connects to the board. Here are the links for the thing to try and read. Let me know.
TRY:
http://support.microsoft.com/kb/555302
READ:
http://search.microsoft.com/results.aspx?mkt=en-US&form=MSHOME&setlang=en-US&q=UNMOUNTABLE_BOOT_VOLUME&x=9&y=6
Posted on Aug 06, 2008
Reset to factory settings
Did your computer come with a recovery disc, Windows disc or have you create a recovery set of discs?
If after reading all of this you find yourself overwhelmed or unwilling to try, take it to a shop.
Another option to the below copied from the Help section to reach the Recovery would be to open the Control Panel. If Category view, under System and Security, select Back up your computer, then Recover system settings, **Then Advanced recovery methods. If in Icon view, select Recovery and you will be at the ** above. There's where the discs above will come into play. If.you don't have any of those, you will have to hope they have a hidden partition on the drive containing the recovery which will either show itself there or in the F8 process below..
To open the System Recovery Options menu on your computer 1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button.
2. Do one of the following:
*If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
*If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter. (If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off.)
4. Select a keyboard layout, and then click Next.
5. On the System Recovery Options menu, click a tool to open it.
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
Dec 07, 2014 | Acer TravelMate Computers & Internet
EMachine EL1850-01e
It looks like you'll have to either return it or perform a default factory recovery. These instructions are from their site but proceed knowing that this will erase any data that is stored on the primary partition (meaning if you have anything on it, it's gone...). Esentially it resets it to a point as if you just picked it up in the store (which you did.. :( )
How can I restore my computer with the backup discs I created?
With user created backups you are able to restore your computer to the factory default settings. If backup discs were created instead of factory restore discs, these can be used instead and will restore the system to a user backup point.
    If you have a recovery disk:
    1. Ensure that the computer is completely shutdown, then turn on the computer.
    2. When the eMachines splash screen appears, tap the Alt and F10 keys simultaneously. A screen stating "Starting eMachines eRecovery" should appear.
    3. From the recovery options, choose Restore system from CD/DVD.
    4. Insert either the first Recovery or Backup disc that you created.
    5. From the on-screen options, choose a backup.
    6. Click OK and the installation will begin.
    7. Change the disc as necessary when prompted.
      If you do not have a recovery disk:
    8. Restart the computer.
    9. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
    10. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
    11. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Dec 13, 2011 | E-Machines eMachines Desktop PC
How do I download or get gateways 500 gr recovery disc ? I need everything reistalled
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
Sep 22, 2011 | Gateway 500GR PC Desktop
Wish to set factory defaults
Sep 20, 2011 | Acer Aspire 5610-4648 Notebook
I got a toshiba satellite pro a100 laptop (psaace- 007002en) second hand and it still has lots of the previous owners files on so I would like to restore it to factory settings but i don't have the...
Sep 20, 2011 | Computers & Internet
My samsung will not boot up and i have no os recovery discs though just downloaded one and that wont boot, tried lots of different options in boot setup and pretty sure its fucoooed removed hd and put it...
I have 2 problems. My Acer Aspire 560z keyboard types garbage for some reason, so I am using an external KB. Then, I want to restore the laptop to factory settings, but the cd's are lost. I don't...
Keyboard - Do you have the NumLock on?
From the ACER support site:
To start the system recovery:
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  6. The computer will boot from the Acer Recovery Media
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Aug 12, 2011 | Acer Aspire 5610 Notebook
How do i reset my settings to factory settings if i cant get to my desktop but i cant do nothing because its on the windows xp??
Note: If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form. If your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Order form:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=Acer
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 10, 2011 | Acer Aspire One PC Notebook
Pc keepestarting after normal shutdown
Try to deselect - automatic restart by doing the following:
start/right click - my computer/properties/
advanced - tab/
startup and recovery- section/settings/
system failure - section/
deselect - automatically restart/if already on/
click ok/
click apply/
Let me know if this helps.
Jan 30, 2010 | Microsoft Computers & Internet
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
Dell Inspiron 1000 Notebook Logo
37 people viewed this question
Alun Cox
