Question about Lenovo ThinkPad T61 Notebook
Hi, I turn on my t61p and it gives a long the two short beeps. Has my motherboard died, or is this a memory issue?
    President:
  • 2,340 Answers
AWARD BIOS beep codes
1 Long, then 2 Short Beeps: Video error
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
Do check your RAM(memory) too. If your RAM is overheating (ie. faulty) you can get this error too.
Hope it helps.
Posted on Apr 05, 2011
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
Boot failure, beeps and no display
Hi.
Do this solution first in the motherboard only processor installed need no memory.then power on your PC.if your motherboard no continues beeping.that need replacement of parts specially capacitor
leakage,became big or burn parts.
See beeping code.
Beep Code:
Description of Problem:
No Beeps
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
Motherboard Problem
Video Problem
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
CPU Overheating
Jun 17, 2011 | Dell Motherboard For Precision 470...
If i reformat my computer, is the beep will not sound again? when i printing my computer begins to beep very long i thought it was the cpu overheating and i put some thermal paste... i turn on my...
Hello
No i doubt the beep will go away if you format.The beep or beeps are trouble codes,a warning something is not right.
Usually related to the cpu,memory sticks,or a video or sound card on the motherboard.or a issue with heat.
Check your motherboard manufacture websight for the codes.Usually a set of short beeps is memory.
Try taking the memory sticks out and reseting them back in.
Jun 16, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
A short beep every second coming through the speakers. I have a citroen C5 HDI. The beep happens even when the cd is playing
Hi royjack74,
a repeated beep is a memory issue. First check for improperly seated or missing memory.
Good Luck
Mark
Dec 11, 2009 | EliteGroup KM400-M2 Motherboard
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Hi, i have an acer aspire 1640z i upgrade my bios from 3a18 to 3a24. after installing my notebook restart and i hear 3 beeps ( 1 long, 2 short) and my lcd doesn't turn on the motherbord work fine. Please...
1 long, 2 short beeps indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
Re-insert the memory into the same slot.
  1. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  2. Try one stick of memory in each slot.
If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify which stick of memory is bad and replace it.
If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard.
The RAM is located under the laptop behind a hidden panel.
Good luck and let me know how you get on and if you need any more help or advice.
Jul 20, 2009 | Computers & Internet
Cusl2-c motherboard problem, no clue what it is
can you give me the beeps explanation. All computers have a standard "beep code" this is a standard code to determine the problems in boot up. Long beeps, short beeps, intermittent beeps all mean something. Can you give me your best definition of the beep codes ? long, short, quick successive beeps etc also can you give the nake and model of the computer.
Chris the computer doctor
Dec 26, 2008 | ASUS Intel 815E Chipset CUSL2-C...
ASUS M2N68-LA Motherboard beeps
The short then long beep error is indicative of a RAM memory issue. I had the same problem and had to use a process of elimination to determine the bad RAM. Place a RAM stick in slot 1 one at a time. The RAM stick(s) that give the short-long beep error are bad. If all RAM gives you the error it is more likely you have a bad board
Sep 03, 2008 | Computers & Internet
Lenovo ThinkPad T61 Notebook Logo
307 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
