Question about American Standard Heating & Cooling
My unit was flooded. I need copy of warranty pertaining to flooding. Model is alllegiance 14
    Brigadier General:
  • 4,736 Answers
Here's a link to American Standard, the manufacturer of the Allegiance 14. As you scan through the document, you will see what's warranted and the length is part is warranted for.
http://www.barkerms.com/pdf/as/allegiance14ac.pdf
Hope this helps you.
Posted on Apr 05, 2011
Neff dishwasher continues to pump
Firstly if you haven't already you should probably check the flood switch with a multimeter, it may move freely but the contacts inside could be fused closed. Only the flood switch activates the drain full time otherwise it is directly controlled by the board so if its not the flood switch its probably the board. If the board has shorted you will likely see evidence of burnout on it.
Jul 08, 2013 | Dishwashers
15000kw hard to start and when it does sounds flooded. turn it off and it starts fine, then turn it off again and acts flooded again. once it starts and runs it will only let you turn on a few
Because it is bad fuel has prevented the float from operating to shut down fuel and unit is running rich that's why it wont power up right don't put fuel cleaner in it now it will only get worse carburetor needs to be taken off and cleaned. get the manual for unit at dealer. you can do it yourself if you are careful ( fuel now days needs a stabilizer in it Amzoil makes the best. It's called PI improver .
when you lay up a machine for the season you need to have this in the fuel ) ethanol messed up shelf life of gasoline try 14 days sitting and you have a problem.
Sep 06, 2012 | Generac Guardian Ultra Source 15,000 Watt...
Flood switch will not reset
The lid seal is damaged and it lets water go through and collect on the flood switch which may be triggering F1.
You will have to replace the lid seal. It is item 8 on page 14 of this diagram.
Jul 27, 2012 | Fisher and Paykel 24 in. DS-603 Built-in...
Basement was flooded and water cover electronics,
TURN OFF ELECTRICITY before touching gas or electric water heater this is or was flooded.
Replace flooded gas or electric water heater.
Warranty is void, all manufacturers say replace water heater, and even if parts are replaced, there is no guarantee that unit will work again.
Resources:
http://waterheatertimer.org/Flooded-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 01, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
F14 error code, and says Flooding. Help please.
F/14 ERROR CAUSES DUE TO:--EEPROM ErrorThe Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU. If there is an error reading this data, it will cuse this error.
TO RESLVE THIS ERROR MANUALLY TRY THIS BEFORE CALLING ENGINEER :--
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
May 06, 2009 | Washing Machines
Tankless Watts Water heater (RA_14) 1 element works
you are not to clear on your problem, watts makes the shut off valves, if you have a tankless water heater is it electric> if so you need to contact your installer if they are not in business anymore contact the water heater company, if you are saying that your sut offs aren't working make sure you have power to the unit, with out power the unit will not let the water go thru, that is one of the saftey non flood features,,
May 05, 2009 | Watts & Tankless Water Heater Service...
My f & p dishdrawer model DD603 has fault code F1:
Yes, you need to gain access to the inside bottom panel of the dishdrawer and drain/dry the water in the bottom panel. When all of the water is gone the polystyrene block will lower and turn off the flood system. You then need to find the reason the unit flooded and rectify it or the unit will just do the same thing again.
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Pump continuing to run -Asko D3100
Micro switch was actually faulty,moisture had entered the switch and caused internal tracking and shorting out the micro switch ,making the pump run continually as it thought it was still in flood mode.
Flood appears to have been caused by a pin hole in the water fill hose in the base of the dishwasher,causing water to spray on the micro switch and eventually biuld up in the base of the machine.
Aug 05, 2008 | Dishwashers
Heating & Cooling Logo
83 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
Pete Norton
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
