The amplifier and speakers we purchased did not come with any wires & the manual is not very descriptive
    Brigadier General:
  • 8,546 Answers
The device you're inquiring about is not showing in your post.
Name the make and model number first, then the manual. Then (maybe) a solution.
Maybe run it by the manufacturer
Posted on Apr 05, 2011
Why is my sub heartbeating and my amp in protection mode
Sounds like a shorted speaker wire. Try disconnecting speaker from amp and see if protection light goes out- if so replace bad speaker wire. Only other issue i can think of from your short description is that you might have a bad ground going to amp or the remote power wire is bad. try running a new ground wire to a clean metallic spot on you cars chassis close to where the amp is located. Good ground = good clean sound
Mar 04, 2011 | Car Audio & Video
Subs Won't work when wired
Based on your post/description, pls try:
1. running the amp's power without the capacitor;
2. manually trigger the amp with the head unit off. Run it an determine if the backfiring still will occur (even with the head unit off);
3. temporarily interchange the left/right wiring;
4. temporarily interchange the + and - speaker wires;
5. run the amp normally trioggered by the headunit but remove the RCA connectors towards the amp.
If your concern has not been corrected or diagnosed which is at fault (wiring, amp, source) after completion of the above procedures, the amp may require an internal look and see.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Lanzar VIBE266 Car Audio Amplifier
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
My amp goes into protection mode when i turn on my car. It gets hot too. I had 2 kicker 12" l5's and blew the subs with that amp, could i just have a simple problem with the amp? What are all my options?
Protection LED on, no output? Amplifi er is very hot = thermal protection is engaged. Test for proper
impedance at the speaker terminals with a VOM meter (see the diagrams in this manual for minimum
recommended impedance and multiple speaker wiring suggestions). Also check for adequate airfl ow around
the amplifi er. Amplifi er shuts down only while vehicle is running = voltage protection circuitry is engaged.
Voltage to the amplifi er is not within the 10–16 volt operating range. Have the vehicle’s charging and electrical
system inspected. Amplifi er will only play at low volume levels = short circuit protection is engaged. Check
for speaker wires shorted to each other or to the vehicle chassis. Check for damaged speakers or speaker(s)
operating below the minimum recommended impedance.
No or low output? Check the balance control on source unit Check the RCA (or speaker input) and
speaker output connections.
Jan 29, 2010 | Kicker ZX10001 Car Audio Amplifier
How to hook up a pyramid pro plus 4 channel pb-180px without using rca jacks for 6 by 9s
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Jul 27, 2009 | Pyramid Audio Players & Recorders
Speaker distortion on high end
Sounds like classic dry joint on speaker terminal ROTELS are well known for it,if you can use a soldering iron or know someone who can resolder the pins where these terminals are connected,always make sure amp is unplugged from wall socket before ...
Dec 18, 2008 | Onkyo M-282 2-Channel Amplifier
Trying to hook up amplifier to after market 6by 9 using factory radio
You can not connect the speaker lines directly to the RCA inputs of your amplifier. But you can connect them to your amplifier if your amp has a high level input. Most of the time it looks just like the speaker jacks of the amp, but smaller. It will be labeled high level input or speaker input. Sometimes an amplifier will have a jack for a wiring harness just for this purpose. Some amplifiers have them and some don't.
If your amplifier does not have them, you can purchase a line level adapter at most anyplace that installs car stereos. it converts the speaker level to the proper level of the RCA input.
Just follow the instructions on how to connect it.
If you try to connect the speaker outputs directly to the RCA input of the amplifier you will blow up the pre-amp in your amplifier.
I hope this was helpful to you, if so a good rating is always appreciated.
Thanks and let me know if you need more help.
Jun 20, 2008 | Car Audio & Video
Component speaker not working
The easiest thing to test is to try swapping the connections of the front component speakers at the amp connections. If the problem follows the speakers, the issue is probably with the speakers. I would triple check (again) the speaker wire connections. It's also possible the crossover for the driver side component speakers has an issue (thus why the tweeter worked for a while).
If the problem stays on the drivers side, the issue is probably with that channel on the amp. Triple check the RCA connections for that channel.
It's much easier to test other speakers on an amp channel versus trying to check it with a meter.
If the driver's door is "abused" often, my initial thought is the wiring at the speaker or the wiring in the speaker (to voice coil, within the crossover, etc) is the most likely culprit.
Apr 10, 2008 | Infinity 475A Car Audio Amplifier
Hooking up a new 8" woofer speaker to my amplifier
If I'm reading the amp manual right, you should be able to connect the amp in 3 channel mode. To do this:
  • Connect both left door speakers in parallel to Ch A Left.
  • Connect both right door speakers in parallel to Ch A Right.
  • Bridge Ch B and connect it to the new 8" sub.
  • Set the Ch A LPF/HPF to HPF.
  • Set the Ch B LPF/HPF to LPF.
This should allow you to run all 4 door speakers and the sub from the amp. It will also automatically route non-bass to the door speakers and "only bass" to the sub.
Mar 22, 2008 | Pioneer GM-6300F Car Audio Amplifier
Protection Light irritation
If the amplifier goes into protect when there are no speaker wires connected to the amp, the amp is likely defective. The most likely culprit is shorted output transistors. If it's new, return it to the place of purchase for repair/replacement.
Sep 28, 2006 | Lanzar VIBE266 Car Audio Amplifier
13 people viewed this question
 Grubhead
Grubhead
