Question about Dometic Rooftop RV Air Conditioner
Duo Therm AC not working
AC unit runs and visual inspection appears to be normal. Air flow appears to diminish over time and the air pumped gets warmer until it is ambient temperature. I suspected compressor or coil freeze up, but unit runs normally and was operating at 90+ ambient temps. Any help would be appreciated.
    Scholar:
  • 121 Answers
If unit was freezing up the air flow would normally stop, until the unit is turned off and allowed to thaw. I suspect evaporator blower may have a worn out belt, or compressor is shutting off due to control or internal overheat. What is the age of the unit?
Posted on Aug 07, 2008
Duo therm 57915.331 not cooling
make sure fan on auto and on cool if ok bad cooling unit
Jul 05, 2012 | Dometic Rooftop RV Air Conditioner
My air conditioner keeps icing up and the flow is then reduced and cooling is diminished. I was recently in a very hot area and the AC was working very hard. I'm in a more reosonable temperature now but...
Check the filters and make sure the coils are clean first. Then make sure both fans are running, the evaporator fan and condenser fan. If all of that is ok then you need to get the refrigerant charge checked.
Jul 23, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm dripping water in camper when shut off. My Dometic Duo Therm Ducted AC drips quite a bit of water when shut off after running for several hours on hot humid days. The condensate lines are open....
Remove the filter at ceiling and run the AC on cool etc, and see if you can feel cool air leaking across to return air inlet where the divider between cold and return is. Check along all edges, etc for any cool air . Careful of wiring, but you should be able to get hand in there and feel especially around the edges where it should be sealed tight. Quite often a leak in that area causes cold air to enter return air and causes excessive condensation. Another thing to check is look way up inside opening for return air, with a flashlight and see if any dirt/dust on coils and fins of evaporator, and if so, needs to be cleaned off with a vacuum, and brush attachment. Let me know what you find.
Jul 10, 2010 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Sep 28, 2009 | Heating & Cooling
AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Have duo-therm ac breaker will kick when temp outside above 85d- most of the time run fine
when it is above 85deg. it will run the freon pump. causing the unit to pull more amps for a longer time. try replacing the breaker with a new one of the same raiting. if this fixes the prob. the have a nice day. if not then you need to get it to a repair center and have it checked by a tech.
Jun 27, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
199 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
